my set up.. cool?
Old Feb 7, 2004 | 09:37 PM
LBR92DA-T's Avatar
Default my set up.. cool?
Bottom end: Dart block, vtec oil/water pump, 8.5:1 84.5 wiseco pistons, crower rods, micropolished crank, 5 qt oil pan, cometic head gasket, arp head studs and rod bolts
Head- Stock gsr with skunk2 intake manifold, hondata intake manifold gasket
Turbo stuff: GT30r, drag intercooler, TiAL sport wastegate, hondata s200b, custom log style manifold, 3.5" dp/exhaust..
Fuel: 255lph walbro, 750cc injectors (w/resistor box), aem fuel rail, aeromotive FPR
my questions are if i exceed 400hp will my intercooler heatsoak? because i've read up that they wont handle past 400 or so hp..
also should i run a p28 or p72 because if i run a p72 they are going to bypass the knock sensor.. but the p28 doesnt have the knock sensor part.. so which one would be a better ecu or does it not matter?
Old Feb 7, 2004 | 09:56 PM
bretx0r's Avatar
Default Re: my set up.. cool? (LBR92DA-T)
get a bigger IC. why 3.5" dp/exhaust? and i dont think it matters with the ecu cause your going standalone.. right?
Old Feb 7, 2004 | 10:06 PM
LBR92DA-T's Avatar
hmm.. 3.5".. going bigger on everything.. might as well.. no use.. might just use a 3" tho.. cuz i found a muffler with 3.5 in's and out's.. thats the only reason.. any suggestions on core sizes? i was thinking 29"x7"x3.5" without endtanks..
Old Feb 7, 2004 | 10:39 PM
15psi of fun's Avatar
Default Re: (LBR92DA-T)
sounds like a good set up i would get a bigger inter cooler
Old Feb 15, 2004 | 05:49 PM
LBR92DA-T's Avatar
making a custom intercooler now...
killacamcivic
Mar 14, 2012 05:47 PM
turbolsvtecej1
Feb 21, 2012 05:39 PM
jmankush
Dec 6, 2007 02:58 PM
jmankush
Dec 4, 2007 09:52 PM
joepiscapo_83
Dec 1, 2004 08:17 AM
