How much Hp can a d16a6 hold
once having a D16A6 and turboing it with fuel management and what not, i do not recommend more then 7 psi on stock internals, but as you said, you have forged rods so it should hold more, but any engine is a dead engine without proper tuning and management
you don't recommend more than 7 psi? rofl!! http://www.homemadeturbo.com go to the forums and ask around.. ppl run 12 PSI on stock internals SAFELY for like 1-3 years. with your setup and proper fuel and timing you should be able to do 15-18 psi safely
yes thank you, i am on thoes boards too, and most guys run 7 - 10 psi, and look at the blown motors section, thoes were all factory internals running more then 8 psi, you never turboed a honda did you? have you ever even made a HMT setup? i doubt it, because anybody that has, knows a honda motor wont survive long on 18 psi with stock internals.
Modified by honda_guy_83 at 4:47 AM 2/13/2004
so how much boost can a d16a6 hold with forged pistons and rods but STOCK sleeves? as was the original question. cuz i wanna know too. with good tuning? with 450cc injectors and a vafc? with no tuning at all?
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
consider asking that in turbo section, most bench racers here do not have personal experience and just propagate rumours.
Stan
Stan
um what are you talking about i said 15-18 psi with HIS set-up.. now look at his first post... forged pistons and rods. and yes my HMT project is done.. RHB5 turbo, DSM SMIC, 1G DSM BOV, V-AFC, DSM 450cc injectors... you need to know more?
blazin
Apr 3, 2003 09:38 AM
