OK to bore stock sleeves to 81.5mm running 18-20 psi?
Is this safe to do....I would normally run 10-14psi on the street but up to 20 psi at the track on C16 occasionally?Also do weisco 9:1 forged pistons have any known probs/weaknesses?Thanks
Re: OK to bore stock sleeves to 81.5mm running 18-20 psi? (blazin)
As long as you've got a standalone. Tuning is your friend, any detonation at that amount of boost = bye bye sleeves.
But it can be done. St00pid has run 20psi through a stock blocked LS engine. Then again he's a pretty nasty tuner.
1 Post
matter of time... before they go? Are ou talking in the sense of "the fact that we're using our motors for performance reasons makes tem wear quicker" or is it due to the overbore? I.E., what kind of boost (or should I say HP) can get from a unsleeved block with this overbore?
Re: OK to bore stock sleeves to 81.5mm running 18-20 psi? (servion)
He means running at that horspower level, the slightest bit of detonation will crack the stock sleeves. People have ran 500whp on stock sleeves. It's just a matter of good tuning and good engine building.
It can be done but it wont last too long.
You can tune the **** out of the computer but remember cylinder pressure is still cylinder pressure. So eventually the sleeves will give way because they weren't built to handle all the pressure for an extended period of time.
You can play it safe by retard the time so much and then dumping fuel in to make it super rich but then you wont be making the power that you should be making at the boost level.
Remember it's not how many psi's of boost, it's how much hp can the stock sleeves hold up. You can be boosting 21 psi on a stock block but only make 300whp, in this situation the stock sleeves can hang maybe. However, if on a different block and your are still boosting 21psi but making over 400whp because you were more agressive with the ignition and fuel table then that's a different story because of cylinder pressure. There is more cylinder pressure from the later example as compared to the first example.
In the end it's a gamble that I wouldn't take if it was my daily driven car because I wouldn't be able to deal with the down time. If however you have another car to drive around while your car is down then go for it. Just make sure you have a good and experienced tuner that can do it.
1 Post
Re: OK to bore stock sleeves to 81.5mm running 18-20 psi? (94goldjungsr)
well... when there are sleeve problems.... to they usually/ever happen up top? Will a blockguard do any good?
Re: OK to bore stock sleeves to 81.5mm running 18-20 psi? (ekb18c)
Get iron ductile sleeves from GE. end of story.
Darton has step decks now too!
1 Post
Re: OK to bore stock sleeves to 81.5mm running 18-20 psi? (93LSivic)
Well... I'm doing a mild build now.... I will sleeve it, but when $$$ is more plentiful. I'm just trying to evaluate what hind of power I can get out of a mild build until I build her again and do _everything_
boostedsohc91hb
14
02-13-2004 09:13 PM
