straight pipe
Weird..I had a straight pipe with my OBDII ECU and no check engine light.
I welded a O2 bung in the straight pipe and still used the 2nd O2 sensor.
Only some CEL's will affect the performance of the car. A CEL for the 2nd O2 wont.
No “limp mode” (loss of power) was noticed with my car.
I was on track a few months ago with a test pipe (did not have time to purchase a high flow cat) and the CEL was on (code #67). There was a noticeable difference in top end power.
William
-who now has a clean rear bumper, a 2.5" SMSP cat and no CEL.
William
Dont kill me on this but what is a test pipe, where can i see a dyno run with one fitted vs stock and how much
A test pipe is a free flowing pipe that replaces the cat. It's called that because it is for off road use only, or for running "testing". Do a search for dyno charts. I believe there is one that shows no difference between a test pipe and a carsound cat.
Look at the 6th pic...
https://honda-tech.com/zerothread?id=65696
This is the mentioned graph...
https://honda-tech.com/zerothread?id=60632
Willis
-who live in a city that has emissions testing.
[sorry that is not the correct graph...
but still cool]
[Modified by Willard, 9:05 PM 10/9/2001]
Willis
but still cool][Modified by Willard, 9:05 PM 10/9/2001]
The gains would be different per the modifications done to the motor.
Slight throttle response improvement... but not the main reason to install one.
The main thing that I noticed (along with some top-end power improvement vs. the full stock system) was the massive reduction of heat along the center console. The shift **** was cooler.
Touching the trunk area above the muffler revealed a warmer feel.
The stains on the right rear of the bumper section were aggravating to remove.
FYI: I installed a “JDM” 4 into 1 header at the same time the test pipe was used.
Will
-who thinks the gains do not outweigh the legal ramifications when using a test pipe.
Will
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chaze*R »</TD></TR><TR><TD CLASS="quote">
Anyone care to comment on this? </TD></TR></TABLE>
Holy 5 year old thread.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso »</TD></TR><TR><TD CLASS="quote">HOLY EXPLETIVE THIS IS OLD!!!
I woke up just to post in this... now going back to bed
cause expletive is such a cool non-poser word to use, rob.
</TD></TR></TABLE>cause expletive is such a cool non-poser word to use, rob.
Dai_Ca_Vietnam_H22a4
May 21, 2005 08:42 PM
Mighty Mouse
Aug 25, 2001 09:30 PM
