straight pipe
Old Oct 9, 2001 | 10:02 AM
rbdynamics's Avatar
New User
Default straight pipe
do u guys recommend to straight pipe a type r? wont my check engine light come on, should i empy my cat, or should i put a test pipe instead?
Old Oct 9, 2001 | 10:05 AM
SMSP's Avatar
Default Re: straight pipe (rbdynamics)
run a test pipe before gutting a cat
B18CXr's Avatar
Hell, anyone here can tell you CEL's are the sign of a fast car........Mine's been on for over a year now.
Old Oct 9, 2001 | 10:46 AM
rezaroy's Avatar
New User
I felt a big difference from my strait pipe. And yes, the engine light will come on. I love seeing that engine light.
Old Oct 9, 2001 | 03:51 PM
rbdynamics's Avatar
New User
Default Re: straight pipe (rezaroy)
when ur engine light comes on, dont you lose a little bit performance???
Old Oct 9, 2001 | 03:57 PM
HX_Guy's Avatar
Weird..I had a straight pipe with my OBDII ECU and no check engine light.
I welded a O2 bung in the straight pipe and still used the 2nd O2 sensor.
Only some CEL's will affect the performance of the car. A CEL for the 2nd O2 wont.
Old Oct 9, 2001 | 04:03 PM
Black SVT's Avatar
Default Re: straight pipe (HX_Guy)
It is a myth that there is a limp mode or some other bs if you have a cel due to the secendary o2 cat sensory.
Old Oct 9, 2001 | 04:23 PM
Willard's Avatar
Default Re: straight pipe (Dc2k-specR)
No “limp mode” (loss of power) was noticed with my car.
I was on track a few months ago with a test pipe (did not have time to purchase a high flow cat) and the CEL was on (code #67). There was a noticeable difference in top end power.
William
-who now has a clean rear bumper, a 2.5" SMSP cat and no CEL.
Old Oct 9, 2001 | 04:52 PM
Luke's Avatar
Default Re: straight pipe (Willard)
Dont kill me on this but what is a test pipe, where can i see a dyno run with one fitted vs stock and how much
Old Oct 9, 2001 | 04:56 PM
slowerthanu's Avatar
New User
Default Re: straight pipe (luke)
Luke a test pipe is a straight piece of exhaust pipe that replaces the Catalytic converter, in the US it is highly illegal and can result in fines if ever used upon a public road, plus it increases pollution considerably, I will be using one for racing though, you can usually get one for under 100$ U.S.
Old Oct 9, 2001 | 04:59 PM
Dr Pooface's Avatar
A test pipe is a free flowing pipe that replaces the cat. It's called that because it is for off road use only, or for running "testing". Do a search for dyno charts. I believe there is one that shows no difference between a test pipe and a carsound cat.
Old Oct 9, 2001 | 05:02 PM
Luke's Avatar
Default Re: straight pipe (Dr Pooface)
Oh Ok, like bypass pipe, cheers for clearing that up
Old Oct 9, 2001 | 05:03 PM
Willard's Avatar
Look at the 6th pic...
https://honda-tech.com/zerothread?id=65696
This is the mentioned graph...
https://honda-tech.com/zerothread?id=60632
Willis
-who live in a city that has emissions testing.
[sorry that is not the correct graph... but still cool]
[Modified by Willard, 9:05 PM 10/9/2001]
Old Oct 9, 2001 | 11:03 PM
Luke's Avatar
Thanks, it looks like overall a gain of 3-5 HP?, but is the throttle response improved?, is it worth it?
Old Oct 10, 2001 | 04:15 AM
Willard's Avatar
The gains would be different per the modifications done to the motor.
Slight throttle response improvement... but not the main reason to install one.
The main thing that I noticed (along with some top-end power improvement vs. the full stock system) was the massive reduction of heat along the center console. The shift **** was cooler.
Touching the trunk area above the muffler revealed a warmer feel.
The stains on the right rear of the bumper section were aggravating to remove.
FYI: I installed a “JDM” 4 into 1 header at the same time the test pipe was used.
Will
-who thinks the gains do not outweigh the legal ramifications when using a test pipe.
Old Oct 10, 2001 | 04:20 AM
DutchITR1689's Avatar
In order to really benefit the higher flow of a testpipe you should remove the bottlenecks and get an 2.5" header.
Old Oct 10, 2001 | 03:06 PM
Luke's Avatar
Default Re: straight pipe (EuroITR1689)
Thanks for all the info. I will probably not bother with a test pipe and instead wait to buy a complete system somewhere.
Old Dec 14, 2005 | 09:09 PM
Chaze*R's Avatar
I've been told that cats don't last long if you're running rich in your setup. For that reason some people side with a straight pipe setup.
Anyone care to comment on this?
Old Dec 14, 2005 | 11:01 PM
Bbasso's Avatar
HOLY EXPLETIVE THIS IS OLD!!!
I woke up just to post in this... now going back to bed
Old Dec 14, 2005 | 11:17 PM
Haleiwa-Brando's Avatar
Default Re: straight pipe (Chaze*R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chaze*R &raquo;</TD></TR><TR><TD CLASS="quote">
Anyone care to comment on this? </TD></TR></TABLE>
Holy 5 year old thread.
Old Dec 14, 2005 | 11:27 PM
uNF$@#!'s Avatar
Default Re: (Bbasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">HOLY EXPLETIVE THIS IS OLD!!!
I woke up just to post in this... now going back to bed </TD></TR></TABLE>
cause expletive is such a cool non-poser word to use, rob.
Old Dec 15, 2005 | 05:46 AM
JDM Factor's Avatar
Ken (BlackR) makes a pretty nice o2 fooler if you ever wanted to get rid of the check engine light.
mfzbike
Feb 10, 2006 02:06 PM
Dai_Ca_Vietnam_H22a4
May 21, 2005 08:42 PM
LillDragun
Apr 9, 2002 02:55 PM
Mighty Mouse
Aug 25, 2001 09:30 PM
1fastGSR
Aug 21, 2001 03:50 PM
