ahh noisy head!
my head started tickin really loud all of the sudden. i checked the oil and i was a little bit low so i added some. now its worse? thers about 57K on the motor(gsr), im thinkin maybe the valves need adjusted?
Im highly highly doubting the rod thing. Could be, but its most likely your valve lash out of spec or your LMAs making noise. Most gsr's make quite a bit of noise to be honest...atleast after some good wear and tear they do.
If your valve lash is in spec, and you know it's coming from the head, then it's most likely the cam journals. I had a LS head that I grabbed from a blown 99 LS motor, threw it onto my built LS block, and when the car got warm, it would make a loud, unbearble tapping noise when driving or revving the motor. Upon further inspection after we tore the head apart, the cam journals were all fubar'd so we replaced the LS head with another.... problem solved. Check your cam journals to see if there's any noticable scratches and/or excessive wear.
jpickett23
10
Apr 13, 2011 11:43 AM
mtkhalid
16
Sep 29, 2008 10:47 PM
mustninty
Aug 3, 2004 01:04 PM
