Funny Noise In engine??
Old Jun 12, 2008 | 09:13 PM
ddtfrom626's Avatar
Default Funny Noise In engine??
Well I just recently got my Head machined and replaced my valve an piston rings by a shop. Although my car runs perfectly fine my engine makes a knocking sound. Im a little worried what could be the problem? Any suggestion or idea would be appreciated.
Old Jun 13, 2008 | 07:23 AM
St. Jimmy's Avatar
* B A N N E D *
Default Re: Funny Noise In engine?? (ddtfrom626)
Have you checked the timing? Do the cam gears line up at TDC?
Old Jun 14, 2008 | 07:14 AM
jayare05's Avatar
Default Re: Funny Noise In engine?? (St. Jimmy)
take that **** back to the shop
Old Jun 14, 2008 | 09:06 AM
ivan93egreppin210's Avatar
Default Re: Funny Noise In engine?? (jayare05)
is it a knock or a tick? does it sound like its coming from the head or oil pan? if it sounds like your head then check your valve lash. did they reuse your rod bearings? if so are they reassembled in the original locations?
Old Jun 14, 2008 | 12:07 PM
ddtfrom626's Avatar
THanks for all the help. I just needed to adjust my valves
user 69782342442
Classic Hondas
13
Mar 4, 2009 12:04 AM
Wes90civic
Mar 14, 2004 06:14 PM
danteisme
Feb 9, 2004 09:22 PM
Logon
Mar 28, 2002 07:19 PM
