heater gets cold at idle
Old Feb 6, 2004 | 12:24 PM
eh2+b18c1=usdm sleeper's Avatar
Default heater gets cold at idle
like the title says: my heat doesnt work at idle...it'll get warm if im driving on the highway. i replaced the thermostat, bleed the cooling system, and checked my hoses and wires.....any suggestions?
Old Feb 6, 2004 | 12:26 PM
JDMlyfestyle's Avatar
might wanna check your blower. some people have found alot of **** blocking the blower which didnt allow it to heat up the car quickly
Old Feb 6, 2004 | 01:04 PM
Default Re: (JDMlifestyle)
im thinking blower...but how would i check the blower w/o actually getting to it...im not really trying to pull my dash if it could be something else. thanks for the reply
Old Feb 6, 2004 | 01:51 PM
da6vtec's Avatar
Default Re: (eh2+b18c1=usdm sleeper)
sounds like it's your water pump, how many miles you got on your motor?
Old Feb 6, 2004 | 01:56 PM
Default Re: (da6vtec)
i was thinking water pump too...cause the heat does warm up almost instantly if i rev it up to about 2000rpm. does that make sense? i rebuilt my motor about 6000mi ago with a new water pump...do you guys think it might have gone poo-poo already? thanks for the replys. its cold in va.
Old Feb 6, 2004 | 02:15 PM
da6vtec's Avatar
does the car ever overheat? have you checked the compression to see if the head gasket is leaking?
Old Feb 6, 2004 | 02:28 PM
it did overheat one day...i changed the thermo and bleed the system that night....it didnt overheat again... but while i was bleeding the system the heater was blowing cold air...now i have this problem. i should do a compression test tonight to see if my motor still loves me.
Old Feb 6, 2004 | 06:11 PM
yellow_jacket's Avatar
What you are describing is usually a case of a blocked heater core. They can get gummed up inside and the pump won't be able to flow well enough at idle to keep it supplied with nice hot antifreeze. Does honda run a block off valve in the heater core lines? You might want to look at that too. What I like to do is take the heater lines off, then take a garden hose and blow the heater core out.
I doubt it is the water pump. In all the years I've worked in shops and on the side I have only seen 1 water pump actually eat the blades up and cause a low flow situation.
Old Feb 6, 2004 | 07:43 PM
b-powa's Avatar
Default Re: (yellow_jacket)
did you check your plugs in the engine bay.. might be disconnected.. i've seen it a few times after a swap.
Old Feb 6, 2004 | 07:49 PM
Smith Wise's Avatar
Default Re: (b-powa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b-powa &raquo;</TD></TR><TR><TD CLASS="quote">did you check your plugs in the engine bay.. might be disconnected.. i've seen it a few times after a swap.</TD></TR></TABLE>
no check the heater core...he said it doesn't work when he idles... but when he's actually driving it will work...
Old Feb 6, 2004 | 08:43 PM
TwoSaints's Avatar
Default Re: (Jswpstdoff)
I have the same exact problem... how would I get to the heater core? I guess im an idiot when it comes to that.
Old Feb 6, 2004 | 10:26 PM
IWearMyKswiss's Avatar
New User
Default Re: (EGCoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGCoupe &raquo;</TD></TR><TR><TD CLASS="quote">I have the same exact problem... how would I get to the heater core? I guess im an idiot when it comes to that.</TD></TR></TABLE>
heater core jobs are good times,..involves taking off the whole ******* dash,..its kinda of a pain in the ***,..not hard at all,.just time consuming
Old Feb 6, 2004 | 11:11 PM
b-powa's Avatar
^^ take the dash out.. it is in the middle of the dash.. taking the dash out is easy.. puting it back suck...
Old Feb 7, 2004 | 07:30 AM
thanks for the suggestions fellas. i got a day off tommorow so im gonna rip the dash out...ill keep you guys updated. thanks for the help.
Old Feb 7, 2004 | 07:40 AM
ATS*Mark's Avatar
OG triple OG
good luck , i had the same problem when my headgasket took a ****.....somthing to think about
Old Feb 8, 2004 | 09:01 AM
slntciv's Avatar
Default Re: (Hella_JDM)
Headgasket is a good possiblity.... could also be the water pump is goin... not having engouh push to get it through the rest of the lines
Old Feb 8, 2004 | 09:41 AM
vtekthis's Avatar
sound like the heater core, if it gone it will not hold the pressure at idle and get cold, but when you drive the hot coolent flows and you get minimal heat right?
EGcivic_95
Nov 19, 2010 09:30 AM
killer_ssn
10
Feb 25, 2007 06:42 PM
97b16hatch
Dec 8, 2006 11:56 AM
Hoosier Daddy
Feb 25, 2004 11:16 AM
gsr-jr
Dec 2, 2002 07:04 PM
