need help bad
if its a 98 hatchback do a Y8 head...MUCH MUCH easier...plus the Y8 head has a better intake manifold as well as a smaller combustion chamber (higher compression)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">if its a 98 hatchback do a Y8 head...MUCH MUCH easier...plus the Y8 head has a better intake manifold as well as a smaller combustion chamber (higher compression)</TD></TR></TABLE>
The Y8 IM is the "Type R" IM of the D.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HATCHingMN »</TD></TR><TR><TD CLASS="quote">Z6 flow better
not sure about power gain compare to y8 though</TD></TR></TABLE>
yeah but then you have to worry aobut the whole OBD2->OBD1 bullshit whereas with the Y8 you can use the stock distributor, IM, exhaust manifold, and everything else
Y7/Y8 mini me (obd2)-
https://honda-tech.com/zerothread?id=735196
https://honda-tech.com/zerothread?id=615978
https://honda-tech.com/zerothread?id=622675
B7/Z6 mini me (obd1)-
https://honda-tech.com/zerothread?id=554053
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98 hatchback dx »</TD></TR><TR><TD CLASS="quote">dahm thanks 4 the treads youv'e been alot of help this should make the whole process alot easier hopefully it the swap goes well...... thanks</TD></TR></TABLE>
Good luck bro
Reply if you have any more questions.
Good luck bro
kamakaze1
Apr 15, 2007 07:35 PM
ArchAngel Sabastian
15
Dec 29, 2003 11:04 AM
trooper0641
17
Oct 9, 2003 05:53 PM
