D16Z6 - D16Y8 Heads
New User
D16Z6 - D16Y8 Heads
Whats the difference between these two heads and could the y8 head be used on the z6 block its a 95 z6 block and a 98 y8 head, thnx
Re: D16Z6 - D16Y8 Heads (ArchAngel Sabastian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ArchAngel Sabastian »</TD></TR><TR><TD CLASS="quote">Whats the difference between these two heads</TD></TR></TABLE>
**** where to start........
Yes you can use the Y8 head on the Z6 block.
I seen many related topics, since i been here on H-T.
From what I've read:
The z6 head flows alot better than the y8. But stock specs, the y8 would yield higher compression.
Correct me if I'm wrong fellas
Re: D16Z6 - D16Y8 Heads (AlphaQup)
It is to my understanding that the z6 head flows better, but the y8 intake/exhaust manifolds were better. So I guess if you use z6 with y8 manifolds, it'd be the best of both worlds.
New User
Re: D16Z6 - D16Y8 Heads (aftermidnight)
well other than looking @ it from a performance aspect this will basicly be a stock car but im having trouble finding a z6 head and i found a y8 head for about 100bux so i was wondering if it would be possible to use that so can i use the y8 head on the stock z6 block with z6 manifolds i have all the parts from the old z6 head but the cam journals are warped/scared and when torqued down the cam wont turn.
z6 head has better ports stock, but the y8 combustion chamber is of a superior design. y8 cam is better than z6 cam stock vs. stock.
A ported y8 head is the best head between the two, IMO.
z6 combustion chamber has 34.6 cc's, while the y8 head has 32.8 cc's. z6 shortblock, you'll gain almost .4 points or so with the y8 head
I want to be MADE into Ice-T
Re: D16Z6 - D16Y8 Heads (337 GTI 1.8t)
AFTERMIDNIGHT "It is to my understanding that the z6 head flows better, but the y8 intake/exhaust manifolds were better. So I guess if you use z6 with y8 manifolds, it'd be the best of both worlds."
what if you have a z6 head thats been ported out on a y8 block with a skunk 2 intake manifold? which would be better y8 IM on a z6 or skunk IM on a z6???
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 337 GTI 1.8t »</TD></TR><TR><TD CLASS="quote">
z6 combustion chamber has 34.6 cc's, while the y8 head has 32.8 cc's. z6 shortblock, you'll gain almost .4 points or so with the y8 head</TD></TR></TABLE>
Here's a picture of the Z6 head.
I'll try to get some pics of the Y8 head, but the difference is that the combustion chamber is more "square" shaped. it doesnt have the CIrcle shape like the z6 heads do.
The top and bottom parts of the combustion chamber near the edges of the valves are "filled in" and flushed with the head surface to give it a smaller combustion chamber volume.
Re: D16Z6 - D16Y8 Heads (exospeedAMcrx)
i've been told that the y8 intake manifold is teh best for a z6 head (more power) what about a skunk2 IM on a z6 head?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AlphaQup »</TD></TR><TR><TD CLASS="quote">I seen many related topics, since i been here on H-T.
Correct me if I'm wrong fellas </TD></TR></TABLE>
yea
yea
Guest
Posts: n/a
Looks good. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exospeedAMcrx »</TD></TR><TR><TD CLASS="quote">here's a Welded combustion chamber we did on a D16A6 head
kamakaze1
04-15-2007 07:35 PM
DRKSol
09-05-2003 07:05 PM
