Max Hp with 440's?
Old Jan 30, 2004 | 12:16 PM
2muchPSI's Avatar
Default Max Hp with 440's?
I was just wandering what is the most whp some of you have made using dsm 440's. My goal is 250 whp on my d16. Are these injectors big enough to get me there safely? Oh, I will be running hondata s200b.
Old Jan 30, 2004 | 12:19 PM
norcalcrx's Avatar
Default Re: Max Hp with 440's? (2muchPSI)
Yes they will be fine. I run a little higher then normal fuel pessure at 65psi but my duty cycle is around 60% @ WOT.
Old Jan 30, 2004 | 12:20 PM
baphomet's Avatar
I will refrain from yelling, flaming, or otherwise insulting since there is that sticky thread.
Follow THIS link, to RC's calculator.
Old Jan 30, 2004 | 01:02 PM
TurboJesse
Guest
Posts: n/a
Default Re: Max Hp with 440's? (slashDEVslashNULL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slashDEVslashNULL &raquo;</TD></TR><TR><TD CLASS="quote">I will refrain from yelling, flaming, or otherwise insulting since there is that sticky thread.
Follow THIS link, to RC's calculator.</TD></TR></TABLE>
for 300bhp i need 550's? thats like 260 whp....Anyways im making 307whp with my 450's, they are pretty close to maxed out though.
Old Jan 30, 2004 | 01:17 PM
baphomet's Avatar
Default Re: Max Hp with 440's? (Mpir3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mpir3 &raquo;</TD></TR><TR><TD CLASS="quote">
for 300bhp i need 550's? thats like 260 whp....Anyways im making 307whp with my 450's, they are pretty close to maxed out though.</TD></TR></TABLE>
You have taken duty cycle and fuel pressure into consideration haven't you?
Or are you saying the calculator is a scam to get us to buy huge injectors?
I always want to learn new things. Feel free to school me.
Old Jan 30, 2004 | 01:23 PM
TurboJesse
Guest
Posts: n/a
I always want to learn new things. Feel free to school me.</TD></TR></TABLE>
yes i did the calculator @ 80% duty cycle and stock fuel pressure...im not saying its anything..maybe i messed something up?
Old Jan 30, 2004 | 01:37 PM
Darin D.'s Avatar
440s will max out right around 300whp. 440s will do 250 whp no problem.
Old Jan 30, 2004 | 02:09 PM
baphomet's Avatar
yes i did the calculator @ 80% duty cycle and stock fuel pressure...im not saying its anything..maybe i messed something up?</TD></TR></TABLE>
eh...I am just wondering. I got greater than 600cc for 300 bhp at 80% Duty cycle, 40psi. I am assuming psig = Fuel pressure at rail in pounds per square inch.
Does this mean we are all operating above 80% duty cycle and/or over stock fuel pressure? I only seek enlightenment.
Old Jan 30, 2004 | 05:24 PM
2muchPSI's Avatar
I'd like to know as well.
Old Jan 30, 2004 | 05:45 PM
Mr.DC2TurBo's Avatar
Default Re: Max Hp with 440's? (Willis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willis &raquo;</TD></TR><TR><TD CLASS="quote">440s will max out right around 300whp. 440s will do 250 whp no problem.</TD></TR></TABLE>
440s max at 320hp
Old Jan 30, 2004 | 05:47 PM
2K_TEG's Avatar
Default Re: Max Hp with 440's? (Mr.DC2TurBo)
anything under 300 and your 440 will be fine.
Old Jan 30, 2004 | 05:49 PM
2muchPSI's Avatar
Default Re: Max Hp with 440's? (2K_TEG)
thanks guys!
Old Jan 31, 2004 | 09:43 AM
baphomet's Avatar
So no one has an explanation for RC's calculator?
Old Jan 31, 2004 | 11:10 AM
1fstevo's Avatar
New User
the problem of using RC calculator is the BSFC #. They tells you to use .60-.65 for turbocharge application but when I calculate my BSFC by using my HP data and pressure, my BSFC comes out .43. That means, i'm in N/A application which is not true. I am assuming their BSFC average data is for domestic vehicles which is less efficient than imports. Try use .40-.45 for BSFC # and see what injector size they recommend. Also play around with the fuel pressure and duty cycle. I run mine max at 90 % duty cycle.
JDMjukie
Mar 19, 2008 10:08 AM
Pee Wee
Jul 20, 2005 05:30 AM
HT Chaplain
Jun 16, 2005 06:40 AM
92HB_HB
May 14, 2004 10:43 AM
egboost
May 28, 2003 03:36 PM
