Will this work well as a internal WG block off??
Old Jan 29, 2004 | 05:01 AM
DA-MAX's Avatar
Default Will this work well as a internal WG block off??
I'm contemplating whether I should either weld the internal WG flapper door shut or just remove it all together and let the flange(as you can see in the pic) act as the block off?? I'm just wondering because could it create some turbulence, being as its sorta like an dead end for the exhaust to get caught up in?? I dunno...any input?
and for those of you not familiar, the internal WG hole would normally be to the right of my thumb.
Old Jan 29, 2004 | 05:22 AM
Ri5e's Avatar
Default Re: Will this work well as a internal WG block off?? (DA-MAX)
Let the flange do the work
When I had my old Drag setup, the turbo used a 5 bolt exhaust housing and there was a hole for an external wastegate setup but it was covered up by the 5 bolt style downpipe flange
Old Jan 29, 2004 | 05:43 AM
DA-MAX's Avatar
Default Re: Will this work well as a internal WG block off?? (BG Boost)
Thanks
Old Jan 29, 2004 | 05:46 AM
30psi Teg's Avatar
Flange will work perfectly fine. Thats all I used.
Old Jan 29, 2004 | 05:55 AM
genop's Avatar
Default Re: Will this work well as a internal WG block off?? (30psi Teg)
I agree, just use the flange.
fabmaster
Feb 22, 2011 07:01 AM
black sohc civic
Aug 24, 2004 09:09 AM
stickshiftt
Apr 6, 2004 08:17 AM
Specialk
Mar 25, 2003 02:11 PM
Slater
Aug 22, 2002 11:08 PM
