Internal to external
Old Mar 25, 2003 | 01:38 PM
Specialk's Avatar
Default Internal to external
i have a used garret t3 that was once internally wastegated. when it was shipeed to me there was no wastegate but there is the hole that goes through the turbine hosing.
that one right above the turbine. now going on my logic allthat would be needed to run an external wastegate is get that hole welded off, is this true? sometimes my logic doesnt work out just right and i wanna be sure it will work befor i order a wastegate.
edit: also the two bottom bolt holes appear to have bolts broken off in them, how hard is it to get those removed? thanks in advance for any help.
[Modified by Specialk, 10:40 PM 3/25/2003]
Old Mar 25, 2003 | 01:52 PM
BoostingSnail's Avatar
Default Re: Internal to external (Specialk)
you can buy block off plates(maybe for less than $25) that bolt up with your downpipe to that housing to block the hole off....then you just need a mani that has a place to bolt up an external WG.
Old Mar 25, 2003 | 01:59 PM
falcongsr's Avatar
What is this crap?
Default Re: Internal to external (BoostingSnail)
if you had the right tools and some thin mild steel, you could make your own. and it would double as a gasket.
use the actual gasket as a template, drill holes for the studs, drill a pilot hole for the turbine exit and then get a metal cutting blade on a jigsaw and cut it out, then trim the thing down to the shape of the gasket.
Specialk's Avatar
sweet thanks man
Old Mar 25, 2003 | 02:11 PM
QCKGSR's Avatar
nice
Turbocivic94
Welding / Fabrication
May 22, 2009 04:56 PM
stickshiftt
Apr 6, 2004 08:17 AM
B18badboy
Nov 26, 2003 11:57 PM
5STAR3
Jul 22, 2003 12:38 PM
