Direct Port Tubing question
i have my install instructions but nowhere in it do i see where to make the connections for the Nitrous tubing to the nozzles, where to place the jets etc.
also, when you make the connection between the tubing and the fitting, how in the world does that stay put?? do you need to flare out the bottom of the tube where it is inside the fitting?
correct me if this is wrong but i believe this is how it is supposed to be so far. the fitting with the silver piece inside sticking out. is that where the jets go?
the tubing goes from the distribution block to the nozzles just make sure fuel goes to the fuel side and nos to its side on the nozzle and youll need to flare the ends of the tubing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blue Streak »</TD></TR><TR><TD CLASS="quote">the tubing goes from the distribution block to the nozzles just make sure fuel goes to the fuel side and nos to its side on the nozzle and youll need to flare the ends of the tubing.</TD></TR></TABLE>
thanks man
thanks man
mongoliandonuts
Feb 28, 2005 09:50 PM
