Largest bore "Off the shelf piston" for a Dseries?
I need some help from someone with experiance on the subject, what exactly is "off the shelf piston". For D series, im guessing that be .20 over the 75mm since thats all I can find. I belive is what it means. I just wondered what the largest bore shelf piston anyone has seen for a D series since the only ones I have are 75mm or .20. Sorry for the newbie post, just a bit confused on it. Thanks,
Matt
Matt
Re: (hatchback19)
.20 is pretty much about the largest you wanna go on a smaller D series man, the more you bore that thing out the thinner the walls are gonna be and the more problems you're gonna see.
.20 is pretty much the largest standard for the oversizing with the D series so to speak...I'm not sure if anyone runs a larger bore than that anyone?
Re: Largest bore "Off the shelf piston" for a Dseries? (hatchback19)
.20" (.5mm) larger is typically the biggest you can get without going custom. Bryson here on h-t had a set of custom 78mm JE pistons made. Those pistons cannot be used with stock sleeves.
Sonny
Sonny
I have a used set of old je .030 over in my possesion. Je no longer advertises any d series in their catalog though.
Re: Largest bore "Off the shelf piston" for a Dseries? (turdbozxi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turdbozxi »</TD></TR><TR><TD CLASS="quote">75.5mm can be used with standard sleeves correct? </TD></TR></TABLE>Yeah, you can go to 75.5 but probably no further safely on stock block.
Re: (llewsirc)
D16Z6 Stock Bore 75mm - Stroke 90
81mm - 1855.3L
80mm - 1809.8L
79mm - 1764.8L
78mm - 1720.4L
77mm- 1676.6L
80mm would be truly pushing the limits being turbo'd, I don't think anyone recommends going more then 78mm althrough I'd like to go 79mm.
81mm - 1855.3L
80mm - 1809.8L
79mm - 1764.8L
78mm - 1720.4L
77mm- 1676.6L
