clutch ?
Old Jan 27, 2004 | 05:00 PM
4door-r's Avatar
Default clutch ?
heres the problem went i start the car in nuetral it wont go into gear but if i start it with it in gear {w/clutch in}clutch holds for a second then i can drive but still shifting is not 100%. is my pressure plate bad or is the whole clutch bad?
Old Jan 27, 2004 | 06:13 PM
doublejz's Avatar
Default Re: clutch ? (4door-r)
make sure its not your master cylinder, or air in your lines. But probably time to buy a clutch kit
Old Jan 27, 2004 | 07:16 PM
pro1342's Avatar
Default Re: clutch ? (doublejz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublejz &raquo;</TD></TR><TR><TD CLASS="quote">make sure its not your master cylinder, or air in your lines. But probably time to buy a clutch kit</TD></TR></TABLE>
Old Jan 27, 2004 | 07:19 PM
Kendall's Avatar
How many miles are on the clutch?
Welcome to Honda-Tech by the way.
Old Jan 28, 2004 | 04:26 PM
4door-r's Avatar
Default Re: (Kendall)
thanks for the welcome,ive been a member but have been away for 6 mon.thanks for the reply i was going to take the tranny out first, i over looked the master cylinder.you might haved saved me a little time.
Chris Miller
Mar 28, 2016 10:49 AM
sfr4dr
Jan 17, 2012 03:14 PM
conceptEG
Aug 13, 2006 02:29 PM
VOLTRONRacing
Nov 4, 2005 06:20 AM
sharktlp
15
Sep 20, 2004 02:11 PM
