whats best intake manifold 2 use?
Old Jan 25, 2004 | 09:44 PM
spoon23_JDizM AkA SpOoN20's Avatar
Default whats best intake manifold 2 use?
being for my 98 ls integra.......stock one ported-skunk-or a sheetmetal....
Old Jan 26, 2004 | 04:50 AM
RedTegLS's Avatar
Default Re: whats best intake manifold 2 use? (spoon20)
There is a large debate and if you search for it I am sure you will find the main thread. If I remember correctly the Skunk2 is helps make lower RPM power and the JG made 7000RPM+ power.
Old Jan 26, 2004 | 04:58 AM
ZoRG's Avatar
Default Re: whats best intake manifold 2 use? (RedTegLS)
the Wilson manifold
Old Jan 26, 2004 | 06:38 AM
MIKES's Avatar
Default Re: whats best intake manifold 2 use? (ZoRG)
that all depends on what whp you are making. For stock motors littly modified, use a skunk2/AEBS/ITR. 400+ use a JG or any other sheetmetal brands.
Old Jan 26, 2004 | 10:10 AM
Default Re: whats best intake manifold 2 use? (MIKES)
was told tho,that if i get a jg manifold it would sit way lower and my intercooler pipes wont fit.
Old Jan 26, 2004 | 10:36 AM
MIKES's Avatar
If your not making 400+ and plan on reving it past 8000rpm, then don't worry about the JG, and if your not going to rev it to 9000rpm forget any brands of sheetmetal intakes These are your only options (skunk2/AEBS/ITR) and it boils down to personal perference. Hp gains between the 3 are minimal.
Old Jan 26, 2004 | 10:39 AM
Arturbo's Avatar
Better than steak
25 Year Member
Put a VTEC head and be done.
Old Jan 26, 2004 | 10:44 AM
PH_B16-VTi's Avatar
https://honda-tech.com/zerothread?id=652605
Old Jan 26, 2004 | 11:54 AM
horror's Avatar
Default Re: whats best intake manifold 2 use? (PH_B16-VTi)
AEBS, cheap and it works , but i think you have to modify it to get it to fit the ls head
Old Apr 14, 2004 | 10:57 PM
1SlowSi's Avatar
Default Re: whats best intake manifold 2 use? (horror)
Hey that brings me to this question. Now, for me i wanna run 280-300whp daily and 400whp for fun once in a while. Would you say that the Skunk 2 manifold would hold up good to 400whp? I know the Edelbrock would yield a litlte more power but, im not worried about 5 or so. I figure Skunk2 because dialy at 300whp, and stock 8200 rev limit, the Edelbrock isnt really getting put to use. It will out flow all around though. I may only increase the revlimit to 8700. And thats it. only because CTR cams.
stock GSR manifold theres been debates
Skunk 2 -- seems best all around for 300-350whp.
JE <--cant go wrong, but may have a little loss in power in the lower rpms.
let me know what you think. Skunk 2 would make life easier with the IC piping.
Modified by 1SlowSi at 8:15 AM 4/15/2004
Bad-T
Nov 11, 2004 08:58 AM
b20vtecv8killer
Oct 22, 2004 05:40 AM
vanillabeans
Jun 26, 2003 10:58 AM
TheTruth709
May 31, 2003 07:28 PM
AGPSuperstar
Feb 10, 2003 08:44 AM
