Newly boosted need input
Old Apr 14, 2004 | 09:45 PM
pornstarSR's Avatar
Default Newly boosted need input
ok so some of you know am now boosted...as seen in other post
https://honda-tech.com/zero...61698
i got some issue though..
here it is
i have a hks gt2510 running 5 psi(basically a garret t25 nissan style with 48ar hot side and 60ar cold side)
fuel setup is vortech fmu 12:1 disc(atleast thats what the guy said that sold it to me)
missing link map bypass
distributor timing 8 degrees
91 octane intank
190gph fuel pump
no CELs
when partial throttle creating boost it bucks and hesitates pretty good
but it gets boost. so thats not the issue, its a smooth spool from the turbo...as far as the gauge shows...which i beleive.
im thinking its the sparkplugs, there the same as my na days.. didnt have the right ones...but since im 5psi i didnt think that would make that much a difference.
i have no inline fuel pump, but i think it will be ok with the higher rate fuel pump i have....but i do have a 255gph fuel pump that i was gona throw in.
so whats the ideas, i want to get it to spool smooth and the car not to hesitate and buck....cause it doesnt feel right.
Modified by pornstarSR at 6:57 AM 4/15/2004
Old Apr 14, 2004 | 10:31 PM
RS Design's Avatar
Default Re: Newly boosted need input (pornstarSR)
you dont need to turn your timing all the way to 8 degrees.. try this rule of thumb... for ever 2 psi go back 1 degree
Old Apr 14, 2004 | 11:24 PM
pornstarSR's Avatar
Default Re: Newly boosted need input (909area)
ok but d series are 12-14 stock...soo
5 psi
so i should run 10 i was thinking that
but i still need help with the hesitation and bucking...i think the missing link is clogged
KrispyKreme
Apr 20, 2005 03:52 PM
zseeanz
Jan 15, 2004 07:07 PM
CM-R
Jun 21, 2002 11:34 AM
Teluan
Sep 5, 2001 09:13 AM
5gen-hybrid
Aug 5, 2001 10:17 AM
