Draft:ls/vtec tuffy try this one
Old Jan 23, 2004 | 07:50 PM
highcomp's Avatar
Default Draft:ls/vtec tuffy try this one
I am lossing oil pressure Im trowing cil 22 on a p28 I tested the oil pressure @1200rpm I get 50psi if I open solinoid via jumping it the pressure drops and the cil comes on wtf Iv tried everything and I not a noob Iv researched the hell out of vtec trouble shooting.
Old Jan 23, 2004 | 08:14 PM
hondatim's Avatar
Default Re: Draft:ls/vtec tuffy try this one (highcomp)
Obviously, it's dropping pressure somewhere.
Has the cylinder head been rebuilt or disassembled and reassembled recently?
Also, how was the oil feed line to VTEC routed and what was used?
Old Jan 23, 2004 | 10:20 PM
highcomp's Avatar
Default Re: Draft:ls/vtec tuffy try this one (hondatim)
yes but i made sure every thing was right at first i forgot to put in the dowl pin under the #3 cam cap but i got a knew one and put it in but no go the vtec comes on for a sec or two then it cuts out maybe the oil orafaces ? i got knew ones coming soon but the one in ther now look fine
Old Jan 23, 2004 | 10:23 PM
highcomp's Avatar
i used a 1/4th to 4an fitting the pressure to the head is fine its like its excaping somewhere in the head do you think if i run air trough that i can see where the oil is leaking. It may be something differnt all together
Old Jan 23, 2004 | 11:48 PM
hondatim's Avatar
I would definitely try compressed air to test. this is also how Honda describes the procedure for testing in the service manual.
Let me know what you find...
I'll help however I can.
Old Jan 29, 2004 | 05:17 PM
highcomp's Avatar
I just put a new post "anyone know vtec"this might get more responses
plus too cold to take it all apart and run air through right now
thanx though
tobster
Mar 13, 2011 12:32 PM
tonymwc
Mar 23, 2008 06:45 AM
b20b
Feb 22, 2002 03:42 AM
zdr262
Oct 23, 2001 09:29 PM
