D series...ARP head stud washers?????
Old Jan 22, 2004 | 07:04 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default D series...ARP head stud washers?????
Ok myself and Hella_JDM were changing out the headgasket and installing the ARP head studs on a Y8 block and noticed there is a 2/3 of an inch gap...we searched and saw a few post of the same problems.....how many others have had this happen?
Also would it be a bad idea to place washers to fill inthe gap?
Old Jan 22, 2004 | 07:57 PM
ATS*Mark's Avatar
OG triple OG
Default Re: D series...ARP head stud washers????? (SnoFlake EG)
bump it up
Old Jan 22, 2004 | 08:16 PM
Marauder's Avatar
Default Re: D series...ARP head stud washers????? (Hella_JDM)
Is the 2/3" on all the studs, or just a couple of them?
Old Jan 22, 2004 | 08:19 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: D series...ARP head stud washers????? (Marauder)
on all of them...we just found out that ARP has 2 different sets for the D series...
Old Jan 22, 2004 | 08:38 PM
ATS*Mark's Avatar
OG triple OG
those pieces of **** , they "JUST" came out with y8 studs , i have the box that just says d16 on it....but these are now the d16z studs.
im gonna go tomorow and get washers to make up for the extra room , hope it works....
Old Jan 22, 2004 | 09:18 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Yo Mark check to see if you can find some at work that we can use...check with airframes.....
Old Jan 22, 2004 | 09:22 PM
ATS*Mark's Avatar
OG triple OG
thats what imma do , i cant even think what i would use......
Old Jan 23, 2004 | 06:49 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Old Jan 23, 2004 | 07:37 AM
Marauder's Avatar
Did you compare the stud lengths to the stock bolts?
Maybe need to run a tap down into the block?
Old Jan 23, 2004 | 07:52 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marauder &raquo;</TD></TR><TR><TD CLASS="quote">Did you compare the stud lengths to the stock bolts?
Maybe need to run a tap down into the block?</TD></TR></TABLE>
i dont think so...the thing is ARP just came out with another set. so theres one for the Y8 block and one for Z6...
Old Jan 23, 2004 | 08:06 AM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM &raquo;</TD></TR><TR><TD CLASS="quote">those pieces of **** , they "JUST" came out with y8 studs , i have the box that just says d16 on it....but these are now the d16z studs.
im gonna go tomorow and get washers to make up for the extra room , hope it works....</TD></TR></TABLE>
They didn't JUST come out with the Y8 head studs. I bought my D16Y ARP head studs last March.
Old Jan 23, 2004 | 08:38 AM
nerdsports's Avatar
Default Re: D series...ARP head stud washers????? (RyanCivic2000)
while putting head studs on my motor (d16y7 block, d16z6 head) i bought the d16 set first. they were too long i believe. i couldnt return them b/c they were scuffed and what not.... i purchased the d16z set and 2 of them were too short. what kind of washers are you guys gonna use?? if its similar to the arp's i say go for it if u cant get the proper set.
i got a set of d16's for sale on my site...check the part# to be sure.
http://www.nerdsports.net/remodel/misc/forsale.htm
CyberC1ren
Dec 2, 2013 10:30 AM
sundownz
Feb 17, 2007 08:27 AM
flashedDc5
Oct 23, 2006 06:46 PM
gubo22
Oct 17, 2006 03:24 PM
Jizzmaster Zero
Sep 6, 2005 10:47 AM
