ARP Studs: D16Y8 Head / D15B7 Block
I searched all over and can't find a definite answer on this one... which ARP studs do I need for a D16Y8 Head on a D15B7 Block? I e-mailed ARP and they want me to do all sorts of measurements and fax in a form... but if someone knows off hand that would be great. Thanks in advance.
I'm almost certain that the one post I DID find regarding this issue said that some of the Y8 studs are not the proper length. It is a mix/match deal... wondering if anyone knows which is which.
Re: ARP Studs: D16Y8 Head / D15B7 Block (sundownz)
Re: (Otherguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Otherguy »</TD></TR><TR><TD CLASS="quote">why the hell are you using arp head studs for a mini me? Use the ones for the block so the b7 head studs </TD></TR></TABLE>
Chill... I am boosting this engine with 12 PSI for now and it is being built to handle over 300 WHP at a later date:
D15B7 Bottom End
0.5mm over-bore
Polished and turned Crankshaft with Microsleeves
Crower D15B7 Forged Rods
Clevite Bearings matched by machine shop
New Mizumo Oil Pump
Custom JE Forged Pistons with 9:1 Compression
D16Y8 Head
ARP Head Studs
D16Y8 Nippon Racing MLS Head Gasket
D16Y8 Intake Manifold
Hondata Intake Manifold Gasket
LS Throttle Body
Home-Made Catch Can Setup using Exhaust Slash-Cut
500cc DeatschWerks Injectors
Walbro 255 LPH Fuel Pump
Stock fuel lines and FPR
Greddy 15G Turbo Charger
Perrin Manual Boost Controller (~12 PSI)
Front Mount Intercooler Setup
Kteller 2.5" Down-Pipe
2.5" Diameter Spun Housing Cat
2.5" Diameter 22" Long Magnaflor Resonator
2.5" Inlet Greddy Evo Knockoff Muffler
2.5" Home-Made Piping (Autozone Parts)
XTR Stage 2 Racing Clutch
Civic DX Transmission (this is my DD and won't see the track)
Night Racing Motor Mount w/ Energy Urethane Bushings
I think I found part of the answer as well:
https://honda-tech.com/zerothread?id=302345
"The ARP studs worked except for the 2 bolts in the back corners of the head. I had to use 2 of the D16y8 head bolts there."
Seems that you use the D15B7 studs except for 2 in the back corners... this guy seems to have used regular bolts from the D16Y8 for those spots... which won't do for me since I am boosting. I guess I'll just have to measure and I'll have an answer for others doing this.
D15B7 Bottom End
0.5mm over-bore
New Mizumo Oil Pump
D16Y8 Head
ARP Head Studs
LS Throttle Body
Okay... did more digging and MAY have found the answer thanks to Bense:
https://honda-tech.com/zerothread?id=1635057
Looks like I need 9x D15B7 studs and 1x D16Y8 stud for my setup!
CyberC1ren
12-02-2013 10:30 AM
