ECU reset?
Old Jan 20, 2004 | 11:51 AM
ABcdEF's Avatar
Default ECU reset?
Ok noob question.. What is the easiest way to reset a stock ECU for a 94 Integra LS?
Old Jan 20, 2004 | 11:56 AM
yojasonyo's Avatar
take off positive on bat. for a few minutes...or you can just take out the fuse in the fuse box...but i take the positive off the bat. for a few minutes, easy enough.
Old Jan 20, 2004 | 11:58 AM
RedTegLS's Avatar
Default Re: ECU reset? (ABcdEF)
Disconnecting the neg battery terminal will reset some things. Or there is a button under the dash somewhere that will reset other things. Do a search for "ecu reset".
Old Jan 20, 2004 | 12:02 PM
timmy8151's Avatar
Default Re: ECU reset? (RedTegLS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedTegLS &raquo;</TD></TR><TR><TD CLASS="quote">Disconnecting the neg battery terminal will reset some things. Or there is a button under the dash somewhere that will reset other things. Do a search for "ecu reset".</TD></TR></TABLE>
The button under the dash is for resetting the Maint Req light.
Another method of resetting the ECU is to pull the 15A and 7.5A fuses from the fuse box. Let the car sit for a couple of minutes and then put back the fuses. Next turn back on the gar and let it idle for about 10-15 minutes, making sure all the accessories are off. Then turn the car off.
Old Jan 20, 2004 | 12:14 PM
Toda Built's Avatar
Default Re: ECU reset? (timmy8151)
yup...just take out the 7.5 fuse for 30sec. then everything will be reset
Modified by Toda Built at 4:55 PM 1/20/2004
Old Jan 20, 2004 | 12:32 PM
es four's Avatar
From: You can be my wingman anytime...., Las Vegas, US
Default Re: ECU reset? (Toda Built)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Toda Built &raquo;</TD></TR><TR><TD CLASS="quote">yup...just take out the 7.5 fuse out for 30sec. then everything will be reset</TD></TR></TABLE>
gutterslide
Jun 3, 2005 09:44 PM
9civic8
Apr 2, 2004 08:51 AM
trooper0641
Jan 2, 2004 10:09 PM
skimb37
May 26, 2003 10:23 AM
SoNNyBoY9o9
Nov 4, 2002 09:23 AM
