quaife differential installation??
Old Jan 17, 2004 | 02:07 PM
R THIS's Avatar
Default quaife differential installation??
does anyone know if a quaife is something that can be installed by me?? or will it require to be sent to a tranny shop for installation?? do they come pre shimmed for the transmission??
Old Jan 17, 2004 | 05:26 PM
PhatOptimo's Avatar
Default Re: quaife differential installation?? (R THIS)
Its not hard to install. Get a helms for the transmition. Get new carrier bearings from the dealer. Have them pressed onto the diff. Also get hem to swap your speedo gear over to your LSD. Measure the outside from the ends of each bearing with a caliper and try to get your new bearings to match that number. If you can get them to match then you won't have to reshim the diff. Kinda hard to explain. Bone probably has a pic of what I am trying to explain.
Old Jan 18, 2004 | 08:00 AM
Wes V's Avatar
Default Re: quaife differential installation?? (PhatOptimo)
It is not hard, but without knowing what you are comfortable doing it's impossible to say if you should take it on.
You will NEED the helms manual in order to split the case and get it back together! You will need a "flat blade" snap ring plier that you can get from Sears. You will need a tube of Hondabond.
And of course, you will need a clean place to work.
You may be able to reuse the carrier bearings. The comment in the prior post should read that you have to check the side to side play and if not correct, you use a different thickness shim.
While the transmission is apart, check the input shaft bearing!!!! If it's in question at all, replace it and the seal. From what I've heard, they tend to go out real fast (the used YS1 that I picked up had a bearing that was real close to being total trash).
Ring gear bolts are "reverse" thread.
Wes
Old Jan 18, 2004 | 08:03 AM
acy76's Avatar
Default Re: quaife differential installation?? (Wes V)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wes V &raquo;</TD></TR><TR><TD CLASS="quote">
Wes</TD></TR></TABLE>
I second this. My YS1 was the same way, and the bearing/seal combo can be had for around $30 online.
Old Jan 18, 2004 | 08:50 PM
R THIS's Avatar
thanx guys, im gonna take it to a tranny shop and get it done, i dont feel like ruining my transmission trying to do this myself!!
Hemix
Transmission & Drivetrain
May 10, 2010 10:54 PM
Hondaruss
Nov 3, 2007 06:04 PM
O RLY
Mar 10, 2006 01:04 PM
mycro_machine
Aug 26, 2002 11:37 AM
Nfurno
Apr 10, 2002 09:00 AM
