Clutch Install Question
Old Jan 17, 2004 | 09:00 AM
FredoSP's Avatar
Default Clutch Install Question
Hey Guys,
Real quick question, me and my buddy are installing an Action 2MS (6 puck sprung) in my 00 Si (B16A2). I got the flywheel resurfaced and torqued it down per the Helms 76 ft/lbs (tho another page says 86.6 ft/lbs, weird).
So with the flywheel torqued down its time for the clutch disk, alignment tool and then the pressure plate. My question is, there's only one way that the clutch disk goes on right? It should be the smooth side aganist the flywheel? The other side (see pic) has a kind of lip or step to it.
I wanted to be 100% this was correct? I'm 99% sure, any help is appreciated.
Thanks
Old Jan 17, 2004 | 09:03 AM
mmuller's Avatar
Mad Scientist
Default Re: Clutch Install Question (FredoSP)
yeah, it will only go 1 way.the flat side towars the flywheel
Old Jan 17, 2004 | 09:11 AM
FredoSP's Avatar
Default Re: Clutch Install Question (mmuller)
Okay so then the way I have it in the picture is correct, right?
Thanks!
Old Jan 17, 2004 | 01:56 PM
Tweakmeister's Avatar
yes, it will only go one way.
the other thing to note is when you put the pressure plate up against the flywheel it won't sit flush (there will be about a .25" gap)...you'll have to bolt it down and then it will sit flush.
Tweak - who broke out the drill and enlarged the PP holes to make it "fit better"
Old Jan 17, 2004 | 06:13 PM
onePOINTsix's Avatar
Default Re: Clutch Install Question (Tweakmeister)
yeah thats right, nice pressure plate
Old Jan 17, 2004 | 06:38 PM
leadfoot78's Avatar
Default Re: Clutch Install Question (Sideout)
Use thread lock on the fly wheel bolts, some times they back out and then it's not pretty.
Old Jan 17, 2004 | 07:04 PM
Se-rv-Tak's Avatar
Default Re: Clutch Install Question (leadfoot78)
that's a nice clutch, how much did that cost you? also just to make note, I know on the stock exedy clutchs from honda, it say's flywheel side, on the clutch hub if you look at it closely. so that side is obviously the "flywheel" side.
but the way you have your's setup is correct, but I really like that clutch . I hear good things about action.. I would really like to know how much that set u back?
Old Jan 17, 2004 | 08:18 PM
FredoSP's Avatar
Default Re: Clutch Install Question (Se-rv-Tak)
Yeah I used Red Locktite
Its an Action 2MS - 6 puck Sprung. I got it from Kyle at wirespeed.com. I think it was 320 or 340.
Old Jan 17, 2004 | 11:56 PM
senpai's Avatar
To be honest, if the flywheel bolts back out then you must have bigger problems than you thought. I've never had problems
Old Jan 18, 2004 | 12:11 AM
MaxSterling's Avatar
looks like you got the clutch disc on backwards....the friction pads on the disc faces the flywheel.
Old Jan 18, 2004 | 05:13 AM
Se-rv-Tak's Avatar
Default Re: Clutch Install Question (MaxSterling)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MaxSterling &raquo;</TD></TR><TR><TD CLASS="quote">looks like you got the clutch disc on backwards....the friction pads on the disc faces the flywheel.</TD></TR></TABLE>
wow... and you know both sides have the friction pads...
Old Jan 18, 2004 | 06:20 AM
FredoSP's Avatar
Default Re: Clutch Install Question (maztur)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maztur &raquo;</TD></TR><TR><TD CLASS="quote">To be honest, if the flywheel bolts back out then you must have bigger problems than you thought. I've never had problems</TD></TR></TABLE>
Hence RED LOCTITE for insurance purposes
Old Jan 18, 2004 | 08:10 AM
doublejz's Avatar
just outta curiosity have you installed a clutch before?
Old Jan 18, 2004 | 08:15 AM
baphomet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MaxSterling &raquo;</TD></TR><TR><TD CLASS="quote">looks like you got the clutch disc on backwards....the friction pads on the disc faces the flywheel.</TD></TR></TABLE>omg, why did you open you mouth when you have no clue on what planet you live?
You (and people like you) are the reason for all the bad advice and bandwagon mentality that is widespread.
Old Jan 18, 2004 | 08:54 AM
Default Re: Clutch Install Question (slashDEVslashNULL)
rofl.
The Action clutches are amazing. I bought a 1KS after my stock clutch (they are made by Exedy) exploded with only 40k miles on it
Old Jan 18, 2004 | 04:43 PM
Se-rv-Tak's Avatar
the action clutch blew after 40k? did you install something wrong? what flywheel is that? and what exactly "blew"?
Old Jan 18, 2004 | 06:59 PM
read again, the STOCK clutch blew at 40k.
the new clutch I installed is a 1KS + Comptech AL
Old Jan 20, 2004 | 09:56 AM
Se-rv-Tak's Avatar
oh ok my bad, i see that now... how much was ur 1ks clutch? with throwout bearing/pilot/pressure/disc/align tool?
Old Jan 20, 2004 | 10:52 AM
Kataku2K3's Avatar
Everything looks good to me, 76 ft/lbs. is the correct spec for a stock flywheel and I too use some red Loctite...
95LssTeg
May 12, 2006 12:16 PM
FredoSP
Jan 17, 2004 02:49 PM
MrEg
Sep 5, 2003 09:57 AM
StinkyTofu
Dec 12, 2002 07:36 PM
