is this too big for my turbo upgrade past my greddy kit??
Old Jan 13, 2004 | 02:09 PM
stackz's Avatar
at the jetties fishin'
Community Builder
Default is this too big for my turbo upgrade past my greddy kit??
ok, I've got a .63/.60 (or did I get that backwards oh well) T3 from an 84 datzun 280z turbo car that my brother got in a large lot of parts from an old nissan repair shop that went out of business. It's brand new in the box and I know how to clock them too so that's not a problem. It's oil-cooled only.
here's my question:
if I took off my TD04H-16G turbo and tossed this on to run @ 8psi would it be too inefficient until I beefed up the lower end to turn up the boost more??
or will it be too big outright for my engine??
thanks guys!
Old Jan 14, 2004 | 04:43 AM
stackz's Avatar
Community Builder
Default Re: is this too big for my turbo upgrade past my greddy kit?? (stackz)
bump
Old Jan 14, 2004 | 05:08 AM
specv5150's Avatar
Where did you get the specs for your turbo from??? I bought a oil cooled T3 from a Z31 (1984-1989 300zx I believe). I checked over at 300zxclub.com and z31.org and no one knew the damn turo specs. I wanna know if this thing is too big for my engine too. Free bump
Old Jan 14, 2004 | 05:42 AM
stackz's Avatar
Community Builder
Default Re: is this too big for my turbo upgrade past my greddy kit?? (specv5150)
they were right there on the housings...
.63 a/r on compressor housing and .60 a/r on the exhaust housing
(or I could have them backwards since I haven't looked at the thing in about 2 months).
Old Jan 14, 2004 | 05:51 AM
specv5150's Avatar
I looked on both housings.....I must have overlooked them. Ill check again. Thanks
Old Jan 14, 2004 | 12:07 PM
dubniK's Avatar
bump!
Old Jan 14, 2004 | 12:16 PM
BlueSi2k's Avatar
Its not really a big turbo but if the exhaust side is .63 it might take a little while to spool. It wont bolt up to your greddy manifold either so your gonna need to get a new mani or some kind of adapter plate. Give it a shot but with a d series you may be better off with at .48 exhaust housing.
Old Jan 14, 2004 | 12:49 PM
Johnyquest's Avatar
Default Re: is this too big for my turbo upgrade past my greddy kit?? (BlueSi2k)
It will spool pretty slow (my t3 .48 spools @ 4k-4.5k), but it won't be "inefficient" at 8psi. It will work fine. When you build, it will be killer.
Good Luck!
stev0_wic
Jul 11, 2010 06:11 AM
ESP-net
Feb 26, 2007 04:59 PM
NosCivic01
May 25, 2006 12:01 PM
rusteds2k
May 11, 2005 03:02 PM
JDM_EH2
Mar 4, 2004 06:56 AM
