Injector size
Old Jan 11, 2004 | 12:12 PM
CRX Si's Avatar
Default Injector size
What size injectors should I run for a N/A 150-175 HP SOHC Vtec?
I was thinking RC 270s or 310s? what do you guys recomend?
Old Jan 11, 2004 | 01:12 PM
hybridmoose's Avatar
Default Re: Injector size (CRX Si)
Those are excellent choices. However if you want to upgrade to FI later I would recommend the 310s.
Old Jan 11, 2004 | 06:26 PM
Kendall's Avatar
Default Re: Injector size (hybridmoose)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridmoose &raquo;</TD></TR><TR><TD CLASS="quote">Those are excellent choices. However if you want to upgrade to FI later I would recommend the 310s.</TD></TR></TABLE>
Agreed completely, but if you have a 175 wheel horsepower N/A d series, then it obviously hasn't been built for boost.
Old Jan 11, 2004 | 06:45 PM
CRX Si's Avatar
Default Re: Injector size (dc231)
cool thanks for the input guys... Im planning out the build up now but Turbo is a possibility in the future... I was thinking 150-175 HP at the fly, internals will be pretty much stock other than some light head work... So if I do boost it in the future it will only be like 6 psi or something along those lines... I just wasnt sure if the 310s would be too much for an N/A sohc, but I think that they would be the best for both worlds...
Thanks again...
Old Jan 11, 2004 | 06:55 PM
hondatim's Avatar
310's will be fine for the NA setup but for a boosted application, you'll have them maxed out in no time.
Just a thought to keep in mind.
Old Jan 12, 2004 | 12:33 PM
CRX Si's Avatar
Default Re: Injector size (hondatim)
cool, thanks for the input
ja20_eg
16
Jan 1, 2008 09:59 AM
rippinitup01
Mar 2, 2007 06:46 AM
pip9
May 12, 2004 03:45 PM
oemDC2
Dec 22, 2003 04:28 PM
omahaturbocivic
Oct 14, 2003 07:26 PM
