What Size Injectors Should I Run!!!
I was wondering what size injectors would be best for my setup which consist of: Revhard mani, Turbonetics t3/t4, 2.5in downpipe, 2.5 inch exhaust, hondata s200B, tial wastegate with .5 bar spring (about 7 psi), custom fmic... Give me your opinions on injector size..
Re: What Size Injectors Should I Run!!! (RedTegLS)
So 440s is the smallest size i should run.. Im planning to stay at that psi for a while.. Not planning to boost that high.. Would 310-370cc be okay?
Re: What Size Injectors Should I Run!!! (oemDC2)
440s will do for now. but like most of us, once you are boosted, you will want more, so do yourself a favor and get at least 550s so you have room to upgrade
Re: What Size Injectors Should I Run!!! (2001teggsr)
On that low of a boost, wouldn't running 550s be an overkill? Wont i have to boost more to compensate for the extra fuel?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oemDC2 »</TD></TR><TR><TD CLASS="quote">On that low of a boost, wouldn't running 550s be an overkill? Wont i have to boost more to compensate for the extra fuel?</TD></TR></TABLE> If u r running hondata u should be able to tune fuel out, but if u have small injectors and it runs lean u wont be able to add fuel.
Cool.. Im thinking about getting some DSM 450's but are their a lot of modifications that need to be done?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oemDC2 »</TD></TR><TR><TD CLASS="quote">Cool.. Im thinking about getting some DSM 450's but are their a lot of modifications that need to be done?</TD></TR></TABLE>no not at all thats what I was running they just need a resistor to operate, u can get a resistor box from any obd1 dsm or honda, or u can buy a 10ohm/ 10volt resistor and run inline at the ecu or at the injector clips
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2001teggsr »</TD></TR><TR><TD CLASS="quote">no not at all thats what I was running they just need a resistor to operate, u can get a resistor box from any obd1 dsm or honda, or u can buy a 10ohm/ 10volt resistor and run inline at the ecu or at the injector clips </TD></TR></TABLE>
I have a OBDI acura, isnt that the same as a OBDI honda?
indeed. just buy some 450's and pay $5 for the 4 10ohm/ 10volt resistors and solder them in...its really not brain surgery
go to homemadeturbo.com and look in the projects section...it tells you how to do everything
Re: (oemDC2)
http://www.ebay.com
http://www.extremepsi.com/x/customer/home.php <-- Big DSM people. Great service.
Re: (Mr.DC2TurBo)
These specs were provided by boosted hybrid:
310cc 200~220whp
370cc 220~280whp
440cc 280~330whp
550cc 330whp~380whp
660cc 380whp~425whp
720cc 425whp~475whp
880cc 475whp~525whp
980cc 525whp~600whp
310cc 200~220whp
370cc 220~280whp
440cc 280~330whp
550cc 330whp~380whp
660cc 380whp~425whp
720cc 425whp~475whp
880cc 475whp~525whp
980cc 525whp~600whp
Re: (sloweg6)
It looks like i will most likely be in the 220~280whp , so i can run 370cc right? Cause a friend of mine has some 370cc and i was thinking about buying them, but might get some 440cc, but im trying to save some money where ever i can at the moment, i will upgrade later if i have to..
