Injector harness adapters.
Old Jan 9, 2004 | 04:47 PM
alphajesse's Avatar
Default Injector harness adapters.
I aquired some 1990 Probe Turbo Injectors (high impedence, flowed by RC to 330cc.)
They use the same type of connector as a RX-7 or Toyota corolla
Thanks to this thread, and bottoz for the pics
https://honda-tech.com/zerothread?id=415342
What I would like to find is either an adapter, so I can use the injectors in the car without splicing the wiring harness, or a source of the male plugs for the stock OBD2 injectors so I can make my own adapter.
The injector I have has a connection just like the one on the left (in red,) and the connector from the Corolla is the next item over. What I need is a plug that matches the stock honda injector, so I can just plug it into my wiring harness.
http://users.adelphia.net/~bot...c.jpg
Any suggestions? Also, what year range corolla uses that clip if I do have to make a trip to the junkyard?
GSR_hatch936
Sep 12, 2009 06:32 PM
95JDM
Mar 7, 2008 12:52 PM
Civic Racer X 7
Nov 2, 2005 01:52 PM
adam meyer
Nov 3, 2003 09:53 PM
Chuckles
Nov 14, 2001 02:22 PM
