Injector interchangeablility?
Old Nov 14, 2001 | 11:43 AM
Chuckles's Avatar
New User
Default Injector interchangeablility?
Do OBD2 injectors use a universal plug on the harness? I'm looking for bigger injectors but don't wish to splice in OBD1 plugs ala RC. I know DSM turbos use 450cc Peak & Hold injectors but wonder if they will plug right into my OBD2 harness plugs? Thanks for the help.
Old Nov 14, 2001 | 11:55 AM
GGrahnVI's Avatar
New User
Default Re: Injector interchangeablility? (Chuckles)
They do not "drop in." Modification is required.
Old Nov 14, 2001 | 12:04 PM
RStoR's Avatar
Default Re: Injector interchangeablility? (GGrahnVI)
What would be required and why?
Old Nov 14, 2001 | 12:16 PM
VTC_CiViC's Avatar
Default Re: Injector interchangeablility? (RStoR)
I did the modification when I installed my RC440's in my 98 Civic, took only about an hour to do all the cutting, splicing and soldering.. easy stuff really.
Old Nov 14, 2001 | 12:17 PM
adam's Avatar
You need the wire clips from RC, just cut them to length and splice them together with stock injector wiring
Old Nov 14, 2001 | 01:45 PM
RStoR's Avatar
Default Re: Injector interchangeablility? (adam)
Ok...call me ignorant, but my question still hasn't been answered directly. GGrahnVI claimed the DSM injectors would not "drop in". I inquired as to why this was. From the answers you guys are posting, it seems that the harness plug is different. If the injectors are OBD2, then why do I need a OBD1 splicer plug from RC or are there two different OBD2 plugs?
Old Nov 14, 2001 | 02:11 PM
98hx99b18c's Avatar
You'll need the obd1 injector plugs to make this fit, either get them from RC or use 92-95 civic injector plugs. On some of the dsm injectors you may have to cut a small notch in the injector plug itself to get the dsm injectors to slide in.
Old Nov 14, 2001 | 02:22 PM
RStoR's Avatar
Default Re: Injector interchangeablility? (98hx99b18c)
Ok...so the DSMs are OBD1. I was lead to believe that they were OBD2.
Thanks for the straight-up answer 98hx99b18c!
SiR99
Apr 29, 2006 10:18 AM
SargentNg
Aug 20, 2005 06:54 PM
KustomCrx
Oct 10, 2004 01:23 PM
turbohf
Nov 7, 2003 11:40 AM
pregunta
Dec 13, 2001 01:22 PM
