wiring question...
Old Jan 9, 2004 | 01:15 PM
colt45.5's Avatar
Default wiring question...
I have a 95 gsr motor in a 98 ex. I have questions concerning the crank sensor behind the crank pulley. I am using my 98 harness with a 95 motor and transmission, ecu, and distributor. What do i do with the ckyp sensor wiring now that i no longer have the sensor behind the crank pulley?
Thanks in advance
Modified by colt45 at 10:48 PM 1/9/2004
Old Jan 9, 2004 | 01:35 PM
FULLTHROTTLE's Avatar
Default Re: wiring question... (colt45)
If you are planning on running OBD-II you need to install an new oilpump and lower timing gear and cover so you can install the sensor and use it. If you are going with OBD-I then all you need to so is neatly button it up somewhere or clip it off and tape it up good so it wont get wet or grounded out by anything.
Old Jan 9, 2004 | 01:39 PM
colt45.5's Avatar
ive got everything but spark, so clearly its related to this issue. I started with a hacked up harness to begin with so that was foolish. It was for a b20 auto trans car as well so it had alot of un
Is anyone aware of the pin locations for the CEL (check engine light circuit) i believe i have a wire snipped for that which is hindering my ability to read the codes. Its not a faulty ecu, i am positive of that because ive tried 3 differant well know ecu's. I have the wiring all finished with just no mods done to the existing 98 ckyp sensor plug, its just hanging there.
Old Jan 9, 2004 | 01:51 PM
The speed sensor on the front of the crank wont hinder it from starting. It is only a crank speed sensor for OBD-II misfire functions.
If you donthave any spark what you need to do is pull the cap off and do a few checks.
Check the black yellow wire on igniter for battery voltage (center pin on side with three pins)
If you have voltage there then you need to check and see if there is dwell at the next pin over (moving towards the side with the single pin coming out)
If you have dwell during cranking at that spot you have a bad coil.
if no dwell switch to other side of the black yellow wire and check for dwell there during cranking. If you have dwell in that spot, you have a bad igniter, if not proceed with code 14 diagnosis in the service manual.
Old Jan 9, 2004 | 01:53 PM
colt45.5's Avatar
I am running a skunk 2 jumper harness and a obd1 p72. but i have this ckyp plug just dangling by where the sensor used to be prior to the b series.
Old Jan 9, 2004 | 02:03 PM
colt45.5's Avatar
WELL ****.
Just help me find a stock ex harness to start out with. ill go from there and see what i can do. I just started out with a junk harness.
Old Jan 9, 2004 | 02:29 PM
Hit the classified section, or a search.
Old Jan 10, 2004 | 07:50 AM
colt45.5's Avatar
Default Re: wiring question... (FULLTHROTTLE)
Yea. the stuff is fine. The harness is ****, cause the motor worked fine in my 93 hatchback with the stock gsr harness.
So, whats another 2 degree winter wiring project.. time to get started with a new knows ek harness.
sweet.!
4drboostking
May 19, 2015 02:37 AM
silver ek
Sep 5, 2005 08:03 AM
colt45.5
Jan 6, 2004 02:41 PM
slowpokesi
Nov 15, 2002 11:19 AM
