'00 B16 into EK coupe tomorrow
ok, the old motor is out and we have started using the wireing harness that came with the '97 coupe. one problem we have run into is the crank angle sensor has a 2 wire plug on the B16 and the OBD2 wireing harness we're using has a 3 wire plug. im sure if i splice 2 of the 3 wires together it will work i just dont know which 2 to use because the colors dont match up. by the way, we are going with the jdm type R ecu. any other wireing problems you guys can think of feel free to enlighten me on because this thing is goin in tomorrow around noon. thanks.
if there is a shield over the wires cut it off and then match up the 2 wires that match in color and tape off the 3rd. that is how i did the wiring on my 00 B16 swap into 96 ek.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kid1320 »</TD></TR><TR><TD CLASS="quote">what wiring harness are you using? a EX wiring harness should plug right up</TD></TR></TABLE>
dats tru. or a SI one. Good Luck!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRAVEDIGGER »</TD></TR><TR><TD CLASS="quote">if there is a shield over the wires cut it off and then match up the 2 wires that match in color and tape off the 3rd. that is how i did the wiring on my 00 B16 swap into 96 ek.</TD></TR></TABLE>
two of the colors are the same they just dont have a stripe on them on the '00 Si crank angle sensor. so ill match thoes two up. we are using the '96 wireing harness for the swap, the B16 harness was too butchered
thanks for the help guys.
thats what i did and the only check engine code we're throwing is crank angle sensor.
96b18c-r
Oct 18, 2011 07:45 PM
