PR3 vs. PW0
Old Jan 8, 2004 | 10:02 AM
Home Skillet's Avatar
Default PR3 vs. PW0
I know this is basic but what are the diffrences between the PR3 and the PW0 ecu?
Old Jan 8, 2004 | 10:30 AM
c jackson's Avatar
threes
Default Re: PR3 vs. PW0 (Home Skillet)
one came out of the siR and the other came out of a xsi
Default Re: PR3 vs. PW0 (c jackson)
but the specs are the same right?
Old Jan 8, 2004 | 10:31 AM
c jackson's Avatar
threes
yes. it has been rumored that there are different fuel maps or something like that, who knows....but if you swapped them in your car you WONT notice a difference.
Old Jan 8, 2004 | 12:55 PM
crxman00's Avatar
i have them both and with my setup I noticed a little better response out of the PR3
Old Jan 8, 2004 | 01:27 PM
c jackson's Avatar
threes
Default Re: (crxman00)
i honestly highly doubt that. im not saying that you didnt feel a better response out of your motor its just that there are so many different variables going into that kind of 'test' that you would notice more of a difference in daytime vs nighttime power. intake air temp for example.
Old Jan 8, 2004 | 01:55 PM
Malgerus's Avatar
Default Re: (c jackson)
From what I understand the Pwo's rev limiter kicks in a little sooner, but the fuel and timing maps are the same (well, this is what Katman says, anyhow).
Old Jan 8, 2004 | 02:07 PM
LD_EGSICK's Avatar
Default Re: (Mr. S)
for me any thing would work right now, i got a pw0 ecu and the vtec doesn't activate
Old Jan 8, 2004 | 02:32 PM
c jackson's Avatar
threes
Default Re: (mysiqu)
that most likely has something to do with your wiring.
Old Jan 8, 2004 | 02:36 PM
bryant's Avatar
They are both the same thing, rev limit, Vtec engagement, and all that stuff. Only thing is the PR3 can easily be chipped while the PWO to my understanding is way different and many places don't even bother.
Old Jan 8, 2004 | 03:26 PM
cursED's Avatar
Default Re: (Bryant)
I believe Kenji still does the FEELS program for the PWO.
Old Jan 9, 2004 | 06:33 PM
kenji's Avatar
25 Year Member
Default Re: (milk)
I can chip both the PW0 and PR3.
Email me at kenji211@tampabay.rr.com if you are interested.
-kenji
Old Jan 9, 2004 | 09:24 PM
biggdogg's Avatar
Default Re: (kenji)
which one takes more kindly to reprogramming ? i always heard the pw0 is more chip or reprogramming friendly .
Old Jan 9, 2004 | 09:28 PM
Malgerus's Avatar
Default Re: (biggdogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by biggdogg &raquo;</TD></TR><TR><TD CLASS="quote">which one takes more kindly to reprogramming ? i always heard the pw0 is more chip or reprogramming friendly .</TD></TR></TABLE>
PR3 is more programmable.
Raene chipped my Pw0 though and I ran a spoon, and feels program for a while. Right now I'm running a self-modified Pw0 program (vtec adjusted, rev limit raised).
Old Jan 13, 2004 | 07:30 AM
crxman00's Avatar
no i'm pretty sure what I felt I even tried it a couple times after reading your reply... there is a small be noticabl difference with the stock PR3 over the PW0.
Old Jan 27, 2004 | 12:22 AM
Malgerus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxman00 &raquo;</TD></TR><TR><TD CLASS="quote">no i'm pretty sure what I felt I even tried it a couple times after reading your reply... there is a small be noticabl difference with the stock PR3 over the PW0.</TD></TR></TABLE>
Your mind is tricking you.
Old Jan 27, 2004 | 04:23 AM
steronz's Avatar
Default Re: (Mr. S)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. S &raquo;</TD></TR><TR><TD CLASS="quote">
Your mind is tricking you.</TD></TR></TABLE>
Although I agree that your mind is tricking you, this might be interesting. You should do a blind study. Have a friend mix them up and plug them into your car without telling you which one is which, then try to guess. You'd have to run like a dozen or so tests, but it wouldn't take too long.
Old Jan 27, 2004 | 10:37 AM
crxman00's Avatar
Default Re: (steronz)
I thought about trying that but I had the PR3 sent off for chipping and since then I had the Pw0 chipped. So we'll never know...
Old Feb 13, 2004 | 08:00 AM
raene's Avatar
Why not just buy a cheap ZIF socket, download free software, buy a $5 EPROM chip, buy a $60 burner and $10 printer cable and program your own damn rev limits, fuel + ignition maps Screw doing 20+ tests to determine a miniscule difference between PR3/PW0, and forget paying cash for a program when you don't know what fuel + ignition it has.
I've run both and noticed absolutely no difference. Now I run self-chipped Uberdata and don't care.
Old Feb 13, 2004 | 07:50 PM
f@sth@tch89's Avatar
Default Re: (raene)
PR3
according to Ericks Racing...a pr3 has more options when it comes to reprogramming.
an old thread i started a while back:
https://honda-tech.com/zerothread?id=595466
Old Feb 15, 2004 | 07:44 PM
sweetsi's Avatar
hey i have the same problem, with my pr3 in my crx with the jdm b16a swap as soon as i reach vtec my motor sounds like it is floating the valves. It looses all go and wont go. I plugged my stock ecu in (pm6) and the motor works just fine. I used to have a vafc and when i would switch it to 6 cyl mode my car wouldnt do it either. Whats up here?
ef-b16sedan
Engine Management and Tuning
Nov 1, 2008 11:17 AM
notorioussabo
Sep 20, 2008 09:15 AM
Young_Matthew
Jul 6, 2004 01:24 AM
XJamesX
Jul 27, 2003 07:44 PM
johnzm
Jul 23, 2002 10:19 AM
