Headlights, how the HELL do I clear out my stock 96 CiViC EX headlights... DAMN THAT AMBER PIECE...
Old Jan 7, 2004 | 07:10 PM
Hoopesciv21's Avatar
Default Headlights, how the HELL do I clear out my stock 96 CiViC EX headlights... DAMN THAT AMBER PIECE...
OK, so I've seen all these people with this done, and instead of buying these expensive *** headlights, I can take off the glass cover, and take out the amber peice... (SO I'VE BEEN TOLD!!!) But I need instructions from someone thats done it... You guys are the **** at this, so PLEASE help a brother out... Nothin but love for all my honda brothers out there... Please help me out, anyone???
Old Jan 7, 2004 | 07:42 PM
tshaw's Avatar
Default Re: Headlights, how the HELL do I clear out my stock 96 CiViC EX headlights... DAMN THAT AMBER PIEC
Im thinking that you put it in the oven and the glue will become soft (well some tailights it worked) but id wait for other suggestions
Old Jan 7, 2004 | 07:46 PM
kKdARIAN's Avatar
Vice President/CEO
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tshaw &raquo;</TD></TR><TR><TD CLASS="quote">Im thinking that you put it in the oven and the glue will become soft (well some tailights it worked) </TD></TR></TABLE>
i did that to my headlights. put them in the oven for a few minutes, let the glue melt... then pull the front housing off.
to put it back on, you do the same thing, heat up alittle, then push the housing back on and hold it for a little bit' let dry.
try searching.. i'm sure there are better instructions out there.
Old Jan 7, 2004 | 08:26 PM
pdiggitydogg's Avatar
^thats all there is too it
under 250*F
under 10mins
over either of those and you run the risk of melting the plastic
make sure you reseal well w/ silicone all the way around or you will get condensation inside and you'll have to pull em off and do it again (silicone I mean...nothing else)
Old Jan 7, 2004 | 08:27 PM
99SlammedCivic's Avatar
Snipper Snapper
Hey, I had people tell me about the oven trick... I was a little scared , so I used a hair dryer... ( takes a while but works the same)
good luck
Old Jan 7, 2004 | 08:29 PM
moondoggy's Avatar
Default Re: (IceCivic18s)
there are some write ups on them. with detail pictures even
just search the archive
Old Jan 7, 2004 | 08:30 PM
Money $hot's Avatar
ya there are better instructions... its called the search function. this topic has been covered at least 20 times.
Old Jan 7, 2004 | 08:33 PM
IWearMyKswiss's Avatar
New User
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">^thats all there is too it
under 250*F
under 10mins
make sure you reseal well w/ silicone all the way around or you will get condensation inside and you'll have to pull em off and do it again (silicone I mean...nothing else)</TD></TR></TABLE>
i did it at 325* and it worked fine for me,..i thnk i left it in for liek 5 mins,..loosen it then put it back in for like 3-4 more mins and it loosen the glue even more,...if you have a heatgun,..it helps,..and it helps to have a friend help you also
Old Jan 8, 2004 | 07:06 AM
tbud454's Avatar
Old Jan 9, 2004 | 11:24 AM
moonchie's Avatar
oven trick? thats kinda gross putting something like a headlight into an oven that you bake your food with. Just do what I did, use a hairdryer and do a portion at a time. Heat up the creases, and slowly pull apart with a wedge of some sort (I used a screwdriver). Then use some compound to reseal, I forgot what kind of glue I used, but I remember I had to mix two different compounds together.
Old Jan 9, 2004 | 11:46 AM
pwrofdrm's Avatar
Where has your headlight been that it's so "gross"?
Old Jan 9, 2004 | 12:01 PM
hondachick81's Avatar
I have wanted to do this...I have heard about the hairdryer and oven tricks before.....but I am just scared I might mess up my headlight!!
headlights aren't cheap!!
seems like all my posts today have been about how much money I don't want to spend...LOL what can I say. I am poor.
My civic has put me in debt
how many ppl have done this successfully. I've counted 4-5 so far, inthis thread.
I know this has been covered many a times, in this forum. So a search might help you.
Or check that thread about the FAQs.
Old Jan 9, 2004 | 12:07 PM
CivicSiRracer69's Avatar
Im sure I have skeeted on my head lights b4, lol B4 I got CF hood I used to love hittin females from the back on the hood of the car... Heat gun works Great! loL, while they are out might as well flat black the housing! FLAT BLACK = JDM in a can!
Old Jan 9, 2004 | 12:16 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civiksiracer1 &raquo;</TD></TR><TR><TD CLASS="quote">Im sure I have skeeted on my head lights b4, lol B4 I got CF hood I used to love hittin females from the back on the hood of the car... Heat gun works Great! loL, while they are out might as well flat black the housing! FLAT BLACK = JDM in a can!
LMFAO!!!! thats great!
Old Jan 9, 2004 | 12:34 PM
thanx! Sorry I almost forgot females search this site as well, Im really not all that shallow,Im more or less like a Creek! lol jk
Tegraracer90
Dec 2, 2007 10:43 PM
tehpr3chr
May 8, 2006 02:26 PM
b18rexracer
13
Oct 27, 2005 09:16 PM
franks98civic
Aug 4, 2004 05:21 PM
ninety9ex
49
Jun 30, 2003 10:47 AM
