trouble at 2500rpm!!
Old Jan 7, 2004 | 09:07 AM
ThefirstPACT's Avatar
Default trouble at 2500rpm!!
The car starts up idles perfect! When i snap the throttle it wants to die and back fires at 2500rpm! I checked grounds there perfect! Any one else have this problem! Also when it hits 2500rpm the check engine light turns on for a second and then shuts off! It dosnt throw a CEL so i dont know if there is a short to the CEL or it throws a code for a second and then it sees everything normal! I need your help i am going to check voltage on all the sensors and see if there correct and then i will go from there!
Old Jan 7, 2004 | 12:23 PM
Default Re: trouble at 2500rpm!! (1CAMcan)
ttt
Old Jan 7, 2004 | 12:43 PM
anyone have anything?
Old Jan 7, 2004 | 12:46 PM
Perfectionist's Avatar
What year/model/engine/etc?
If the ECU lights the CEL even briefly, it should store a code.
Old Jan 7, 2004 | 01:59 PM
Default Re: trouble at 2500rpm!! (Perfectionist)
Sorry, 90 si civic! It dosnt store a code i am stumped!
Old Jan 7, 2004 | 02:29 PM
payneth's Avatar
hopefully you get that thing working correctly. that doesnt sound like a good thing thats happening.
Old Jan 7, 2004 | 02:55 PM
Default Re: (OneSloEF)
well thats why i am asking the question...anyone?
Old Jan 7, 2004 | 03:08 PM
chadmasterc's Avatar
Default Re: (1CAMcan)
Have you done any work to the car recently that might be causing this? Did it run normally and then one day just do this?
Old Jan 8, 2004 | 06:33 AM
Default Re: (chadmasterc)
after a swap! The car had no engine to begin with! I just put in a stock motor!
Old Jan 8, 2004 | 09:16 AM
ttt
Old Jan 8, 2004 | 09:52 AM
Bgladfelter's Avatar
Does it do this in gear or in nuetral? Both?
Is it a regular Si motor that you put in?
Old Jan 8, 2004 | 10:04 AM
Default Re: (Bgladfelter)
in neutral only! Havent taken it out on the road so really i dont know if it does it driving! The motor came out of the same year hatch(90) I recieved it from a friend who did a swap for a kid!
I am going home today and i am gonna check some things out! Pull exhaust maybe its clogged! Also do you think valves could be a problem? If they're not within spec?
Old Jan 8, 2004 | 04:19 PM
nota944mechanic's Avatar
it sounds like an ignition problem. what is the condition of the ignition parts? does the tach jump around when this is happening?
Old Jan 8, 2004 | 04:38 PM
Doug684's Avatar
I agree, I had this same problem and it started getting worse and worse after time. Turned out it was my dizzy.
Old Jan 9, 2004 | 10:01 AM
Default Re: (Doug294)
well i've replaced the cap,rotor,coil,plugs and wires! And yes the tach jumps around when it "acts" up!
Old Jan 9, 2004 | 12:52 PM
ttt
Old Jan 9, 2004 | 02:17 PM
you may need a distributor. i will do some more research and get back to you.
Old Jan 9, 2004 | 03:37 PM
Default Re: (nota944mechanic)
cool sounds good!
Old Jan 10, 2004 | 06:26 AM
ttt
anyone else with any ideas! I am going to try a new dizzy!
Old Jan 10, 2004 | 07:59 AM
altoid's Avatar
do you have a frayed spark plug wire? if so is the clutch cable hitting it? if so then you're grounding out one of your sparks.
Old Jan 10, 2004 | 10:34 AM
Default Re: (altoid)
brand new wires!!
Old Jan 10, 2004 | 11:53 AM
ttt keep'em coming!
Old Jan 11, 2004 | 07:17 AM
yeah im pretty sure its the distributor.
D0kt3r
17
Mar 18, 2016 06:24 PM
jst17
Acura TSX
Mar 25, 2014 06:16 AM
prophecy7115
Mar 17, 2008 08:40 AM
Fatty_1775
Jul 20, 2003 10:23 PM
