How do u install new flywheel???
Old Jan 6, 2004 | 07:30 PM
Soccerking3000's Avatar
Default How do u install new flywheel???
as in the title i was wondering and i searched and found nothing i would really like to know if anyone is currently removing their tranny and would like to make a write up on removing the tranny and then installing a flywheel, much rather install myself than have a shop do it for 400 dollars it would be awesome or just some advice on how to go about doing it,
thanks in advance
Old Jan 6, 2004 | 07:35 PM
cxSHOE's Avatar
Default Re: How do u install new flywheel??? (Soccerking3000)
get the helms manual in my sig..
Old Jan 6, 2004 | 07:37 PM
Default Re: How do u install new flywheel??? (cxSHOE)
i already got one but i was wondering if anyone has done and had some advice mainly cause i don't want to **** this up cause it is my only car, et cetera, or if anyone has had any problems while doing it or things to look out for.
1 point 6's Avatar
Down Since Day 1
Community Builder
Community Influencer
The hardest part is going to be removing your tranny. Once you get past the axel and 12 bolts, and figuring out you need to take the 3ft starter bolts out. Then youll see the bolts to take the clutch and PP off then youll see the bolts to get the flywheel off.
The most intimidating thing is getting the tranny off, once its off you pretty much have to be blind not to figure it out.
Old Jan 6, 2004 | 07:41 PM
Default Re: How do u install new flywheel??? (1 point 6)
okay is it really hard to get out cause i do not have a lift, of course i have stands and a jack but will that be enough room to remove it??
Old Jan 6, 2004 | 07:44 PM
cxSHOE's Avatar
its pretty straight forward once the trans is out... i would say your hardest will be putting the trans back in. if your doing it by yourself... and just remember to follow the manual and you'll be fine...
Old Jan 6, 2004 | 07:47 PM
me fine..... i am prolly gunna break somethin but i will have my friends help but the manual is pretty straight forward?? cause i want this to be as smooth as possible,
ohh and how long would you say this should take, and would it be a good idea to change my clutch as well while i am at it?
Old Jan 6, 2004 | 07:48 PM
1 point 6's Avatar
Down Since Day 1
Community Builder
I do it all the time with jack stands and a jack.
Just secure the car from behind like with wheel chocks & ebrake.
Put the jack stands behind the front wheels, make sure its secure.
Start unhooking the sensors that are attached to the tranny, you can just take off that 1 bracket.
Drain the tranny.
Take off the clutch lines.
Start removing all the bolts.
The tranny will not drop off due to its dowell pins.
Secure the tranny on a jack and start pulling it off.
Get a screw driver and pry between the block and tranny, it will come right off.
Before you get to that point though, you have to tackle the axel. I know Tom did a grear write up on axel removal and you should search for, "FAQ axel removal"
A quick rundown....
Remove the 32mm hub nut.
Remove the castle nut on the control arm.
Remove the clip on the axel nearest the tranny.
Grab as close as you can to the tranny and get a pry bar, have someone pry on the axel while you jiggle it out.
Once its out, bang it out of the hub to get it lose.
Use a pickle fork to seperate your ball joint.
Move your hub assembly out of the way while pushing the axel out.
When the axel is out, just lay it to the side or pull it all the way out through the fork.
Rough directions, but you get the idea of what your facing.
Id give this a 7/10 job for the whole job if you know your way around a car.
Old Jan 6, 2004 | 07:53 PM
doesn't sound to bad pretty stright forward but how long cause in the next week i would only ave around 5 hours to do this will i have enough time the car needs to be running after that 5 hours
Old Jan 6, 2004 | 07:54 PM
1 point 6's Avatar
Down Since Day 1
Community Builder
5 hours should be enough with some buddies.
But I always give myself pleanty of time, cause **** WILL go wrong.
Id give myself a full day, 8 hours with breaks.
Old Jan 6, 2004 | 07:56 PM
ekb18cCivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxSHOE &raquo;</TD></TR><TR><TD CLASS="quote">get the helms manual in my sig..</TD></TR></TABLE> how bout you throw and ek manual into your sig or post up some one who has the ek manual accesible online i'd go out and buy it but i dont have that much money to blow . im trying to get the rest of the **** for my swap.. my haynes catalog will have to do until ..unless you have the link
Old Jan 6, 2004 | 07:58 PM
cxSHOE's Avatar
yea take the breaks when you start getting pissed off...
if your like me more **** starts to break when im pissed off.
Old Jan 6, 2004 | 07:59 PM
cxSHOE's Avatar
Default Re: How do u install new flywheel??? (ekb18cCivic)
i dont have the manuals link to me personally. and he has no more space to put another manual on there...
if you need it pm me...
Old Jan 6, 2004 | 08:00 PM
thanks guys that helped a ton but i want it to go smoothly &lt;crosses fingers&gt; but i will have 2 friends helping me out and we will work pretty diligently, so i think we should get it done i hope if all fails and my car blows up i will drive one of my friends car or make them my personal chauffeur
Old Jan 6, 2004 | 08:01 PM
should i put a new clutch in at the same time or once i do it once it will be easier the second time and won't be any or much less trouble than the first time
Old Jan 6, 2004 | 08:02 PM
1 point 6's Avatar
Down Since Day 1
Community Builder
Haha true that, just take your time and make a plan in the morning, things go better planned than "ah **** lets just rip it apart" like so many of us do.
Good luck! Let us know.
Old Jan 6, 2004 | 08:06 PM
i am going to make a write up for it so be ready for it in a week or so
Old Jan 6, 2004 | 08:13 PM
1 point 6's Avatar
Down Since Day 1
Community Builder
Sounds good!
Take pics.
Old Jan 6, 2004 | 08:17 PM
Bailhatch's Avatar
You really should get a new clutch. It will seat much better on the new flywheel and will obviously last longer than your used one. Also you may find the hub on the disc or the springs are loose, then you'll have to wait until you get a new clutch before you put it back together.
cavrdave
Nov 19, 2004 06:06 AM
dat_flip
Sep 4, 2004 05:25 PM
AK94GSR
Mar 21, 2003 01:10 PM
SpoonFedHatch
10
Feb 20, 2003 07:09 PM
Kamin
Oct 21, 2001 03:14 PM
