Stupid F*cking Greddy blue box
Old Jan 6, 2004 | 07:07 AM
igo4bmx's Avatar
Default Stupid F*cking Greddy blue box
I'm driving to school today and my car started hesitating around 1500-2000 rpms, everytime i would be in partial throttle my car would jerk back on forth...
didn't look good in front of the college chicks lol
This has happen a couple times where i start the car and immediately it hesistates!
anyone think its just a bad blue box?
Old Jan 6, 2004 | 07:10 AM
ArchAngel Sabastian's Avatar
New User
Where do you live, and does this happen always @ 1500-2000 or only when its(engine) cold.
If so you should probably let it warm up
Old Jan 6, 2004 | 07:18 AM
igo4bmx's Avatar
Default Re: (ArchAngel Sabastian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ArchAngel Sabastian &raquo;</TD></TR><TR><TD CLASS="quote">Where do you live, and does this happen always @ 1500-2000 or only when its(engine) cold.
If so you should probably let it warm up</TD></TR></TABLE>
im in philly,
i was driving for a good 40 minutes then suddenly this started to happen
Old Jan 6, 2004 | 08:36 AM
Del_Slowest's Avatar
Default Re: (igo4bmx)
post pics of the chicks.....hehe
Old Jan 6, 2004 | 08:49 AM
gdrum's Avatar
Default Re: (Del_Slowest)
yeah i wanna see the chix
Old Jan 6, 2004 | 04:03 PM
igo4bmx's Avatar
pictures come after the solution to my problem
Old Jan 6, 2004 | 04:05 PM
your TPS sensor is working correctly?
could just take blue box out and see what it runs like without hitting boost. Not sure if you can change your wastegate spring easily or not. guess you could just unbolt some of your exhaust bolts so it creates an exhaust leak therefore raising your spool up time if you wanna be a lil safter
Old Jan 6, 2004 | 04:13 PM
BlueSi2k's Avatar
that happened to me when one of my injector clips came off and was running on 3 cyls. Check them as well as the spark plug wires and new plugs wouldn't hurt.
Old Jan 6, 2004 | 05:34 PM
igo4bmx's Avatar
Default Re: (BlueSi2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueSi2k &raquo;</TD></TR><TR><TD CLASS="quote">that happened to me when one of my injector clips came off and was running on 3 cyls. Check them as well as the spark plug wires and new plugs wouldn't hurt.</TD></TR></TABLE>
oohsthats and idea...
i'm gonna have to check on this... will keep you updated
Old Jan 6, 2004 | 05:38 PM
BDTURBO's Avatar
Default Re: Stupid F*cking Greddy blue box (igo4bmx)
Sounds exactly like what mine does, I adjusted the wiring and now it doesnt happen, check all connections, its probably a loose wire!
Old Jan 6, 2004 | 07:27 PM
igo4bmx's Avatar
Default Re: Stupid F*cking Greddy blue box (BDTURBO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BDTURBO &raquo;</TD></TR><TR><TD CLASS="quote">Sounds exactly like what mine does, I adjusted the wiring and now it doesnt happen, check all connections, its probably a loose wire!</TD></TR></TABLE>
hmm now gotta check that... even though i soldered them all
Old Jan 6, 2004 | 07:56 PM
Bailhatch's Avatar
Check distributer. look for shaft play on the rotor.
Old Jan 19, 2004 | 05:43 PM
hondaeg8's Avatar
did you ever find a fix for this? was it the blue box? i'm having the same problem now. i'm thinking it could be the blue box.
mine would hesitate bad at all different kinds of rpms...i could never get passed 5k though.
could you put a missing link instead of using the blue box?
Old Jan 30, 2004 | 11:31 AM
dropgear's Avatar
'missing link' is no replacement for the blue box. Missing link + AFC/eManage + larger injectors IS a replacement for the blue box.
Old Jan 30, 2004 | 12:05 PM
91obd1teg's Avatar
r u running irdium plugs???? if so take them out a run run v-power or platnium NGK's.
Old Jan 30, 2004 | 04:26 PM
igo4bmx's Avatar
i have a feeling its my IACV doing this (its an auto by the way)
because of two things
my CEL 14 is going on
and this occurs only after driving it hard
I tink my radiator fluid is boiling to the point that maybe the air that is created as steam is messing with the IACV?
Old Jan 31, 2004 | 12:38 AM
Nick7's Avatar
Default Re: Stupid F*cking Greddy blue box (91obd1teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91obd1teg &raquo;</TD></TR><TR><TD CLASS="quote">r u running irdium plugs???? if so take them out a run run v-power or platnium NGK's.</TD></TR></TABLE>
I'm runnign Denso Iridium plugs on my honda... though use FMU, still no problems at all... works flawlessly
Why would iridium plugs cause trouble? AFAIK they even have better spark than regular platinum...
Old Jan 31, 2004 | 03:27 AM
EFb18b's Avatar
Default Re: (dropgear)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dropgear &raquo;</TD></TR><TR><TD CLASS="quote">'missing link' is no replacement for the blue box. Missing link + AFC/eManage + larger injectors IS a replacement for the blue box.</TD></TR></TABLE>
yeah but its SO much easier to deal with than that POS
Old Jan 31, 2004 | 08:27 AM
kranked91dx's Avatar
Default Re: Stupid F*cking Greddy blue box (Nick7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nick7 &raquo;</TD></TR><TR><TD CLASS="quote">
Why would iridium plugs cause trouble? AFAIK they even have better spark than regular platinum...</TD></TR></TABLE>
I was wondering the same thing, I'v runned Denso Iridium plug's for the last summer without any problem.
Kranked
Old Apr 19, 2004 | 01:46 PM
93TurboSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igo4bmx &raquo;</TD></TR><TR><TD CLASS="quote">i have a feeling its my IACV doing this (its an auto by the way)
I tink my radiator fluid is boiling to the point that maybe the air that is created as steam is messing with the IACV?</TD></TR></TABLE>
if you coolant is boiling then you are overheating which can cause misses while its to hot. also could be boiling due to bad headgasket which can make plugs prematurly dirty.
Also i noticed i got through plugs like crazy(ngk one step colder) with the turbo. They look fine when i remove them but i have lots of skips and hesitation and when i put fresh ones in the skips and stuff go away. I probably have to do this like every 3-4 months. maybe i'll try another step cold but i would try throwing a set of plugs in and seeing if it fixes the prob plus its cheap.
Old Apr 19, 2004 | 02:10 PM
igo4bmx's Avatar
Default Re: (93TurboSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93TurboSi &raquo;</TD></TR><TR><TD CLASS="quote">if you coolant is boiling then you are overheating which can cause misses while its to hot. also could be boiling due to bad headgasket which can make plugs prematurly dirty.
Also i noticed i got through plugs like crazy(ngk one step colder) with the turbo. They look fine when i remove them but i have lots of skips and hesitation and when i put fresh ones in the skips and stuff go away. I probably have to do this like every 3-4 months. maybe i'll try another step cold but i would try throwing a set of plugs in and seeing if it fixes the prob plus its cheap. </TD></TR></TABLE>
wow this came back from the dead!!
this issue is over since i switched to a 5 speed and now run a 2 wire IACV
EX-T
Mar 5, 2006 08:42 PM
cxjon
Dec 30, 2004 06:38 PM
Honda-Hooligan
Oct 28, 2003 08:34 PM
jdmacura
Sep 12, 2003 03:40 AM
MachAF
Jun 28, 2003 10:19 AM
