Synthetic or regular?
Old Jan 3, 2004 | 11:31 PM
Redek4's Avatar
Default Synthetic or regular?
Got my motor rebuilt, and the mechanic said that after I break in the motor I should switch to synthetic oil. Thing is I heard it doesn't bond well with the metal...That true?
Old Jan 3, 2004 | 11:43 PM
mmuller's Avatar
Mad Scientist
Default Re: Synthetic or regular? (Redek4)
mmmm, no its not true...
after break in, switch to syn.
Old Jan 4, 2004 | 12:29 AM
iam7head's Avatar
Default Re: Synthetic or regular? (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">mmmm, no its not true...
after break in, switch to syn.</TD></TR></TABLE>
huh?
yeah, the technician is right, syn. oil lube so well, that is not recommend for new engine, you will experience leaky gasket because the rings and seal is not properly break in and seal.
i wouldnt even change oil until 5000 on a new car/engine.
Old Jan 4, 2004 | 12:45 AM
mmuller's Avatar
Mad Scientist
Default Re: Synthetic or regular? (iam7head)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head &raquo;</TD></TR><TR><TD CLASS="quote">
huh?
they dont recommend using syn. during break in, cause syntethic oil forms a coating on the metal making it more ''slippery''.
thats why rings dont seal good if you use syn. oil during break in...
Your right, I wouldnt switch to syn. oil untill after 5000 miles.
defenetely change the oil...
Old Jan 4, 2004 | 12:54 AM
iam7head's Avatar
one of the reason why syn. oil is better is because they love to "stick" to the metal to make a "cushion" of oil, in this case that's not what you what for your new motor.
that's pretty much it
Old Jan 4, 2004 | 08:49 AM
ITR_1211's Avatar
First oil change, synthetic
Old Jan 4, 2004 | 10:40 AM
Jer's Avatar
Jer
Default Re: Synthetic or regular? (Darryl Musashi)
say what you guys want, but syn oil is really not any better than dino if you change your oil on the regular.
syn oils main advantage is that it can last longer than dino. but if you want to keep oil in your engine for more than 3k be my guest.
do a search, there is thread going for twenty some pages all about syn vs dino. its long but very informative.
i have since switched back to good ol castrol gtx from mobil1. i used to burn about a quart or so over a 3k mile oil change. now using dino and still driving just as agressive(autox mainly) i dont burn any at all. just change your oil around 2500-3k and ALWAYS change your filter at the same time.
Old Jan 4, 2004 | 11:13 AM
rudebwoy's Avatar
I think you sould change your oil like every 100 mile during breakin period using regular oil, to help clean out any loose metal/dirt/etc and then after break in mobil1<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">
defenetely change the oil...</TD></TR></TABLE>
Old Jan 4, 2004 | 03:13 PM
mmuller's Avatar
Mad Scientist
Default Re: Synthetic or regular? (rudebwoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rudebwoy &raquo;</TD></TR><TR><TD CLASS="quote">I think you sould change your oil like every 100 mile during breakin period using regular oil, to help clean out any loose metal/dirt/etc and then after break in mobil1</TD></TR></TABLE>
Yes i defenetely change the oil sometimes even once a week during break in...
regular non detergent oil that is..
what i sayd is not to use syn. untill after break in..
builtITRm22x
Sep 9, 2008 10:54 AM
djdownfawl
Honda Civic (2001 - 2005)
13
Apr 18, 2008 02:38 PM
J.nguyen
Honda S2000
16
May 19, 2007 09:02 AM
hondaeg8
Jul 13, 2005 03:49 AM
quazar
11
Oct 23, 2004 05:50 AM
