ARp head studs install
Old Jan 2, 2004 | 09:18 AM
sikcrx80's Avatar
Default ARp head studs install
i am about to install my arp head studs. i was wondering if someone knows the web site that shows me what the torqe specs are and the three step in torqe them in... cant seem to find them
did a search cant seem to find anything
Old Jan 2, 2004 | 09:20 AM
onePOINTsix's Avatar
Default Re: ARp head studs install (sikcrx80)
did you do a archive search? know i've seen it on here before
Old Jan 2, 2004 | 09:21 AM
Default Re: ARp head studs install (Sideout)
here you go https://honda-tech.com/zerothread?id=279313
Old Jan 2, 2004 | 09:57 AM
sikcrx80's Avatar
one guy says 70 ft/lbs is that right?
Old Jan 2, 2004 | 10:05 AM
irev210's Avatar
Default Re: (sikcrx80)
i do all of mine to 67-68ft/lbs
call arp and they will tell you 67ft/lbs
1st step I do it to 33ft/lbs
I dont do 3 steps, just 2
70 will work also
I noticed that the new ARP head studs have a allen key on top so u dont have to double nut the arps anymore too, really sweet stuff.
DONT use a 3/8" drive
Old Jan 2, 2004 | 11:52 AM
sikcrx80's Avatar
why not use a 3/8 drive
Old Jan 2, 2004 | 12:10 PM
irev210's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sikcrx80 &raquo;</TD></TR><TR><TD CLASS="quote">why not use a 3/8 drive
well for 33ft/lbs 3/8th deep is fine, just dont use a regular 3/8ths because it doesnt cover the nut all the way, also at 68 ft/lbs 3/8ths can break. With a 1/2" drive torque wrench the handle is alot longer giving you more torque to tighten the head studs with less effort giving more acurate torque #'s
Thats imo Im sure u can take a 3/8th drive with a deep well'd 1/2" 12point socket and be fine
Old Jan 8, 2004 | 08:02 AM
nicklk's Avatar
So do you torque the studs into the block at 67lbs, THEN torque the nuts onto the head at 67lbs too??? Or do you seat the studs into the block at 15lbs, then torque the nuts onto the head at 67lbs??
Old Jan 8, 2004 | 10:24 AM
rtype11's Avatar
Default Re: (nicklk)
seat the studs finger tight only make sure they need zero force to seat otherwise tap the threads, make sure the the threads are precleaned and well oiled/assembly lube.... sequence is the same as honda manual.
think its:
7-3-1-5-9
8-4-2-6-10
Flexin5
May 19, 2007 05:26 PM
W O T
Jun 11, 2006 09:48 PM
existanzcivicb20
May 9, 2006 01:06 PM
CRX_DOHC_ZC
16
Mar 11, 2006 09:24 PM
UncleBen'sRacing
Apr 25, 2004 02:50 PM
