INSTALLING HEAD STUDS
Old Apr 4, 2006 | 08:25 AM
existanzcivicb20's Avatar
Default INSTALLING HEAD STUDS
ok im installing ARP head studs on my b20 now my ? is do I have to trq them down on to the block? or just screw them in hand tight?
Old Apr 4, 2006 | 08:30 AM
SpeedingHatch's Avatar
Default Re: INSTALLING HEAD STUDS (existanzcivicb20)
lube them up, and turn the screws into the block hand tight. Then torque down the bolts in increments.
Old Apr 4, 2006 | 09:13 AM
Default Re: INSTALLING HEAD STUDS (SpeedingHatch)
ok so just trq them down with the head in the proper sequence rit
Old Apr 4, 2006 | 09:41 AM
onefstek's Avatar
I usually lube them and install them by hand all the way down, then tighten them down 1/4 turn with an allan wrench.
Old Apr 4, 2006 | 09:45 AM
jfoster's Avatar
Default Re: (onefstek)
Do all Bseries ARP head studs have the same torque spec?
Does it matter if its their second use?
Old Apr 4, 2006 | 09:58 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onefstek &raquo;</TD></TR><TR><TD CLASS="quote">I usually lube them and install them by hand all the way down, then tighten them down 1/4 turn with an allan wrench. </TD></TR></TABLE>
Yeah, thats what I did.
This is helpful too:
https://honda-tech.com/zerothread?id=1404959
Old Apr 4, 2006 | 10:04 AM
Default Re: (SpeedingHatch)
what should i torque them down to
Old Apr 4, 2006 | 10:15 AM
Default Re: (existanzcivicb20)
the arp studs are for a gsr im putting them in my b20 with gsr head so what should I torque them to
Old Apr 4, 2006 | 10:21 AM
jfoster's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by existanzcivicb20 &raquo;</TD></TR><TR><TD CLASS="quote"> the arp studs are for a gsr im putting them in my b20 with gsr head so what should I torque them to </TD></TR></TABLE>
same question. I have gsr studs that are going in a b18b block with a b16 head. Used once before.
Old Apr 4, 2006 | 10:25 AM
Should say on the pink slip in the box. I think its like 70 with the supplied lube or 80 with 10w30 oil.
Old Apr 4, 2006 | 10:37 AM
ok all my ? are done thanks every one for the help
mike1114's Avatar
My AEBS headstuds said to torqe them down to 10lbs with an allen wrench when installing them in the block. ARP could be different though.
Old Apr 4, 2006 | 12:57 PM
EARLdaSQUIRREL's Avatar
official honda whore
Default Re: (mike1114)
dont lube the bottom threads, tq down to 10 ft lbs with allen wrench*hand tight* make sure you clean up all the threads before even doin this, then install head, lube top threads and tq to 70 ft lbs
Old May 9, 2006 | 01:06 PM
drintegra's Avatar
Default Re: (coptzer)
do you need to take all of the bolts off or can you replace bolts individually until all are replaced. Trying to not take off the head.
95_red_dc
Aug 31, 2008 06:17 PM
95_red_dc
Aug 31, 2008 09:28 AM
boost fed ls
Jan 6, 2006 06:10 PM
LudEcrous
May 4, 2004 01:47 PM
UncleBen'sRacing
Apr 25, 2004 02:50 PM
