how do external wastegates work ( search used, bashers go elsewhere)
Old Dec 26, 2003 | 05:21 PM
7thGear's Avatar
Default how do external wastegates work ( search used, bashers go elsewhere)
ok, from looking at internaly wastegated turbos i see that you have 2 holes, and i'm assuming that once the turbine reaches its limit, the other little hole opens up and lets out the exess gas
however, both gases go into your exhaust
but what about an external wastegate??? if its external where da hell does the exess gas go?? i'm a little stumped
thanks.
Old Dec 26, 2003 | 05:31 PM
accordfreak's Avatar
Default Re: how do external wastegates work (7thGear)
out in the open air or routed back to your exhaust
mine's routed back into the exhaust cuz i hate the sound
Jared's Avatar
external wastegates work the same way as internal, they bleed off exhaust before it gets to the turbo to regulate turbine speed. You can either dump it to the atmosphere or back into the exhaust after the turbo.
Old Dec 26, 2003 | 05:32 PM
7thGear's Avatar
Default Re: how do external wastegates work (accordfreak)
but.... if its routed out.... doesnt it like... have horrible emmisions since this is pre cat???
Old Dec 26, 2003 | 06:43 PM
fulldragcrx's Avatar
emissions are not an issue if you route the dump tube back into the exhaust system. also alot quieter this way.
Old Dec 26, 2003 | 06:52 PM
TeStUdO's Avatar
Default Re: how do external wastegates work (fulldragcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fulldragcrx &raquo;</TD></TR><TR><TD CLASS="quote">emissions are not an issue if you route the dump tube back into the exhaust system. also alot quieter this way.</TD></TR></TABLE>
If you route it back into the exhaust be sure to do it at least 18 incehes past the turbo. This is so the exhaust doesnt create unwanted back pressure.
Old Dec 26, 2003 | 06:54 PM
Bailhatch's Avatar
dumping the WG gasses out of the exhaust can effectively give you more peak flow after you reach your boost limit and the WG is dumping off a certain % or the gasses to atmos. People even convert internal gates to dump externally i assume for this reason, maybe the sound too
From my experiences, emissions usually aren't an issuer if you go aftermarket turbo anyway
Old Dec 26, 2003 | 08:08 PM
7thGear's Avatar
Default Re: how do external wastegates work (Bailhatch)
so then, you would have your external wastagate thingy, and then weld a pipe over it and back into the exhaust a little bit further down the line?
where would the cat go? after the whole thing connects back together again?
Old Dec 26, 2003 | 11:13 PM
Dr Pooface's Avatar
Here is a pic of my external WG.
On my car, the small stainless pipe carries the exhaust from the WG and releases it to the atmosphere below. This pipe could be connected to the exhaust pipe, before the cat, as seen a few posts above.
Old Dec 27, 2003 | 11:28 AM
7thGear's Avatar
Default Re: how do external wastegates work (Dr Pooface)
so a true external wastegate is really for a race only application, since any cop driving next to your car will be able to smell the fumes??
Old Dec 27, 2003 | 11:32 AM
Ri5e's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 7thGear &raquo;</TD></TR><TR><TD CLASS="quote">so a true external wastegate is really for a race only application, since any cop driving next to your car will be able to smell the fumes??</TD></TR></TABLE>
That's if your putting a lot of load on the engine and making max boost (If running a boost controller that opens the wastegate right when it hits the max boost setting) or close to max boost (Running without a boost controller)
Old Dec 27, 2003 | 12:36 PM
integracivic94's Avatar
Default Re: how do external wastegates work (BG Boost)
what sort of noise does the external wastegate make???? is it loud? sorry to jack your thread dude!!!!
Old Dec 27, 2003 | 02:08 PM
Burke's Avatar
Banned
Default Re: how do external wastegates work (integracivic94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integracivic94 &raquo;</TD></TR><TR><TD CLASS="quote">what sort of noise does the external wastegate make???? is it loud? sorry to jack your thread dude!!!!</TD></TR></TABLE>
BBBWWWWWHHHAAAAAPPPPPP!!!!!!!!
i like it
Old Dec 27, 2003 | 07:04 PM
Dengar's Avatar
Default Re: how do external wastegates work (Burke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Burke &raquo;</TD></TR><TR><TD CLASS="quote">
Just like that.. I can't even explain it. When my friend's wastegate opens on his teg it sounds almost mustangish and heads turn like something is about to explode.
Old Dec 27, 2003 | 07:22 PM
7thGear's Avatar
Default Re: how do external wastegates work (Dengar)
when cars sound like there gonna explode... they usualy do :D
Old Dec 27, 2003 | 10:00 PM
ratttat tat tat tatat tat tat tat tata tatata tat lawn mower on crack
Old Dec 27, 2003 | 10:16 PM
HXMan's Avatar
Definatly gets heads turning....people look over and think WTF?! THen you beat their ***! (hopefully)
rorik
May 28, 2008 01:11 PM
biggmike2
Jun 26, 2004 08:28 PM
JDM 007
Nov 7, 2003 11:14 PM
prelittlelude
Jul 30, 2003 12:10 PM
SoulSurfer
Oct 20, 2002 02:05 PM
