Broke a exhaust manifold stud deep within the head
Old Dec 23, 2003 | 07:53 AM
P1mpSlap's Avatar
Default Broke a exhaust manifold stud deep within the head
I broke a exhaust manifold stud deep within the head.
What do I need to do to remove it? Drill it out and retap it? I've heard you can slit a line in the middle of the stud and attempt to use a flat head to twist it out, but it's pretty deep in there.
What should I do?
Old Dec 23, 2003 | 08:59 AM
Gabe_'s Avatar
Default Re: Broke a exhaust manifold stud deep within the head (P1mpSlap)
Try one of the two things you mentioned...
Also, there is a tool you can buy for doing exactly that. I forget what it is called. Perhaps someone can help me out... Just go to sears, and tell them what is going on, and they will hook it up.
Old Dec 23, 2003 | 09:08 AM
rapid_roy's Avatar
Default Re: Broke a exhaust manifold stud deep within the head (Gabe_)
An 'extractor' I believe.
Cheers,
Roy
Old Dec 23, 2003 | 09:15 AM
Doctor CorteZ's Avatar
drill out and retap , your going to have to use a helicoil if you wish to retain the same size bolts/stud.
Old Dec 23, 2003 | 09:30 AM
P1mpSlap's Avatar
Default Re: Broke a exhaust manifold stud deep within the head (Doctor CorteZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doctor CorteZ &raquo;</TD></TR><TR><TD CLASS="quote">drill out and retap , your going to have to use a helicoil if you wish to retain the same size bolts/stud.</TD></TR></TABLE>
I think that's my only option.
I'm gonna get a friends dad to do it for me, I guess. Frankly I have no money to spend on an extractor of any kind.
Old Dec 23, 2003 | 10:09 AM
cyvic's Avatar
you can do it yourself. It's pretty easy. The screw extractor only cost $1-$2. You drill a hole in the the broken stud with the correct drill bit size and use the extractor and screw backwards. the extractor is threaded backwards. But be carefull not to break the extractor because it's hard to drill it out.
Old Dec 23, 2003 | 05:50 PM
P1mpSlap's Avatar
A screw extractor wont cut it. Just asked a few guys it's too deep within the head.
I have to drill it out.
Does anyone know what EXACT drill bit I should use to drill it out?
Old Dec 23, 2003 | 06:04 PM
mr.beeks's Avatar
Default Re: (P1mpSlap)
two sizes less than the diameter of the bolt
measure how deep the bolt goes into the head
then place a hose over the bit making sure that
is not going to go deeper into the head
Old Dec 23, 2003 | 06:15 PM
oMek's Avatar
Default Re: (mr.beeks)
ok bro, i just did this like 2 months ago, i got colbalt bits from sears. i broke 3 of them drilling a hole in the bolt, i keept drilling untill the bit wint threw the end of the stud. then i hammerd a screw extractor in and it came right out.
total cost was like 10$
just make sure u get COLBALT bits (they are strongest i hear) and also make sure they dont give you a wood screw extractor.
2 secs ill post a pic of the 1 u need
Old Dec 23, 2003 | 06:21 PM
oMek's Avatar
Default Re: (oMekoneDC2)
its a 1/8th screw extractor.
good luck with the build up
Old Dec 23, 2003 | 06:30 PM
db8sirg's Avatar
you can always take it to the machine shop.
you are going to get the head re-surfaced right?
Old Dec 23, 2003 | 06:51 PM
oMek's Avatar
Default Re: (db8sirg)
https://honda-tech.com/zerothread?id=567450
check that out bro, i hade to buy a angled drill to fit in the spot. then i just took it back to the store after
Old Dec 23, 2003 | 08:51 PM
P1mpSlap's Avatar
well I have the head off the block... so it'll be easier. I'm going to try that method first. Resort to a tap and die last.
Old Dec 23, 2003 | 09:40 PM
WhitEdRift's Avatar
Since broken studs is the topic maybe you guys can give me a hand too. A while back I broke a stud holding my valve cover on. It was just the tip that went into the nut though, so a good portion of it is exposed. Is it possible to just unscrew the old stud and screw in a new one?
If so what type of studs do you all recommend? I've seen several "performance" studs but OEM might be the way to go. I dunno...
Old Dec 23, 2003 | 09:54 PM
integra_gsr98's Avatar
Default Re: (WhitEdRift)
I'd opt for the heliacoil if I was you. Go to your local auto parts store and purchase the proper helia coil kit. It will tell you what size drill bit and what tap to use. Then just follow the instructions to install the helia coil and away you go!
Old Dec 23, 2003 | 10:05 PM
oMek's Avatar
Default Re: (integra_gsr98)
also bro, if i was you ide get the civic SI bolts. they are 1 peice and alot easer to use then a nut and a stud.
Old Dec 23, 2003 | 11:00 PM
tilt's Avatar
yep i did that method too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oMekoneDC2 &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=567450
check that out bro, i hade to buy a angled drill to fit in the spot. then i just took it back to the store after</TD></TR></TABLE>
invader_zim
Jan 24, 2013 09:19 PM
Mr. Vapor
May 10, 2007 07:50 AM
98B18C1
Nov 15, 2005 12:18 PM
kyden
Apr 11, 2005 07:58 AM
Flamenco-T
May 21, 2002 05:36 AM
