Stripped Exhaust Manifold Bolts/threads
Old 02-08-2006, 12:28 PM
Mr. Vapor's Avatar
Default Stripped Exhaust Manifold Bolts/threads
Ok,
I did a search on Helicoils vs timecerts and came up with inconclusive results...its seems divided 50/50 and most of the posts were in reference to head studs, not what im dealing with.
so on my '00 Civic Si, Honda for some reason or another decided to use only two Studs on the exhaust manifold side of the head, all the rest of bolts which screw into the head. After having my manifold off and on many times ive managed to strip out 2 of the holes in my head. the rest ive replaced with Studs so i wont have this problem.
now, the two that are stripped, what are my options and what is recommended? ive never worked with helicoils or anything of that nature so can this procedure be done with the head ON the block? i assume ill be able have enough room with my A/C out and the manifold off the car etc.
what would you guys recommend?
anyone know by chance what size helicoil i need or what the thread/pitch of the factory bolts for the exhaust manifold are?
help!
Old 02-08-2006, 02:29 PM
Too_Smooth's Avatar
Default Re: Stripped Exhaust Manifold Bolts/threads (Mr. Vapor)
Just fixed a stripped hole in my head the other day. It's a M8x1.25. I fixed it right in the car without any problems. Got the Helicoil right from Advance. Good luck....it's pretty easy...just take your time.
Old 02-08-2006, 03:00 PM
Moderator in Chief
Muckman's Avatar
I would epoxy the studs in there. If you do it clean you wont be able to tell. I have the same problem on one of mine.
Old 05-10-2007, 03:48 AM
dannydos's Avatar
Default Re: Stripped Exhaust Manifold Bolts/threads (Muckman)
i have two stripped holes also on my exhaust side.....what did you end up doing....??? anybody else have an good advice
Old 05-10-2007, 07:50 AM
Top Ramen's Avatar
Default Re: Stripped Exhaust Manifold Bolts/threads (dannydos)
I love the Time-Sert stuff. Its just better engineered than helicoil. If you have room to line the tap up on the hole, you have room to repair the threads in place. Fix it right with these and it will be much stronger than the original aluminum threads ever were,
Best of luck with your project.
8Gomer9
23
03-12-2017 03:05 PM
invader_zim
01-24-2013 09:19 PM
98B18C1
11-15-2005 12:18 PM
legendboy
07-30-2003 12:47 PM
Flamenco-T
05-21-2002 05:36 AM
Quick Reply: Stripped Exhaust Manifold Bolts/threads
