How much power from a turbo b16a......?
Old Dec 22, 2003 | 03:52 PM
The Crow's Avatar
Default How much power from a turbo b16a......?
I have a freind that is putting a turbo on his stock b16 powered 94 hatch. What kind of power have you guys seen with a t3/t4e and Hondata on this kind of setup?
Old Dec 22, 2003 | 04:07 PM
JGurr81's Avatar
Default Re: How much power from a turbo b16a......? (The Crow)
There are lots of T3/T4's out there. An SC-61 is a T3/T4 and people have made 550+ with that. Theres also smaller T3/T4's like 50, 54, 57 trim available too. There are also many different variables to know what kinda numbers he would put down so we kinda need more info on the setup and what kinda T3/T4 he is running
Old Dec 22, 2003 | 04:29 PM
nigel's Avatar
I am planning on 275 whp. I have that setup. I am also on hondata.
Old Dec 22, 2003 | 05:09 PM
TurboJesse
Guest
Posts: n/a
Default Re: (nigel)
im running a t3/t4 on a stock b16a, I made 307whp 212wtq, wanted more but my injectors were maxed..
Old Dec 22, 2003 | 05:43 PM
The Crow's Avatar
Default Re: (Mpir3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mpir3 &raquo;</TD></TR><TR><TD CLASS="quote">im running a t3/t4 on a stock b16a, I made 307whp 212wtq, wanted more but my injectors were maxed..</TD></TR></TABLE>
What are the specs on your turbo and how much boost are you running?
Old Dec 22, 2003 | 06:21 PM
TurboJesse
Guest
Posts: n/a
Default Re: (The Crow)
t3/to4e 60 trim, was at ~14psi, really conservative tune, 11:8 a/f in boost.
Old Dec 22, 2003 | 07:56 PM
markaria's Avatar
Default Re: (Mpir3)
which injectors were you using?
Old Dec 22, 2003 | 08:03 PM
TurboJesse
Guest
Posts: n/a
Default Re: (markaria)
i was planning on using 550's (was shooting for 350whp) but i had problems with the 550's and had to throw in some DSM 450's.
Old Dec 22, 2003 | 08:14 PM
r7's Avatar
r7
Default Re: (Mpir3)
check signature
Old Dec 23, 2003 | 07:23 AM
The Crow's Avatar
Default Re: (r7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r7 &raquo;</TD></TR><TR><TD CLASS="quote">check signature</TD></TR></TABLE>
Because his b16 is a gen 2, with better cams and a higher CR, I think his numbers should be a little higher than yours. He said he wants about 300hp at 10psi. He plans on running race gas to pull this off.
Old Dec 23, 2003 | 07:34 AM
TurboJesse
Guest
Posts: n/a
what size t3/t4? hes prolly gonna need more than 10psi to hit 300whp, also race gas isn't needed.
Old Dec 28, 2003 | 03:03 PM
RyanAutry's Avatar
Default Re: (Mpir3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mpir3 &raquo;</TD></TR><TR><TD CLASS="quote">i was planning on using 550's (was shooting for 350whp) but i had problems with the 550's and had to throw in some DSM 450's.</TD></TR></TABLE>
What was your static fuel pressure set to when you made the 307whp w/those 450's?
What dyno?
Thanks.
Old Dec 29, 2003 | 09:41 AM
TurboJesse
Guest
Posts: n/a
Default Re: (RyanAutry)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanAutry &raquo;</TD></TR><TR><TD CLASS="quote">
What dyno?
Thanks. </TD></TR></TABLE>
it was a OEM FPR...Dynojet
Old Dec 29, 2003 | 09:46 AM
RyanAutry's Avatar
Default Re: (Mpir3)
it was a OEM FPR...Dynojet</TD></TR></TABLE>
That's good to know. Do you think my 440's will be good for 285whp w/ stock fuel pressure and high volume pump?
Old Dec 29, 2003 | 10:51 AM
kleefton's Avatar
I doubt it.
Once you put a high volume pump your pressure will go up anyway, so it won't be stock fuel pressure. Get a fuel pressure gauge, and get a regulator to set it to whatever.
My guess is 440s will be completely maxed out at that power level.
Old Dec 29, 2003 | 04:32 PM
ykracing's Avatar
Default Re: (kleefton)
I pulled 325whp on an MD dyno.
turbo stock b16, with a 3" dump, on VP c16 for safety...
Old Dec 29, 2003 | 04:52 PM
porsche997dc2's Avatar
Default Re: (trboCIVICWRX)
May be this will help you out a little.
https://honda-tech.com/zerothread?id=712430
Old Dec 30, 2003 | 12:19 PM
TurboJesse
Guest
Posts: n/a
yea, i have a walbro 255hp too...
Old Jan 11, 2004 | 09:10 PM
r7's Avatar
r7
Default Re: (Mpir3)
hm, maybe i should turn the boost to 10psi and tune
i have 780cc injectors in already.. . i duno about stock motors and 10psi though.. .
Vovchandr
Jan 13, 2007 08:34 AM
crxnj
Dec 22, 2005 10:04 AM
wpgcivic
Jul 18, 2004 09:24 PM
CiViC SiR
Mar 20, 2004 05:17 AM
B18PoweredCivic
Dec 30, 2002 10:05 AM
