CRX Timing & dist question
Old Dec 22, 2003 | 12:01 PM
415CRXSI's Avatar
Default CRX Timing & dist question
can anyone tell me what the correct specs are?
also looking to locate the no 1 Cylinder sensor in my distributor
many thanks
Old Dec 22, 2003 | 12:50 PM
415CRXSI's Avatar
Default Re: CRX Timing & dist question (415CRXSI)
anybody? please help, need to get this running and finish Xmas shopping
thanks
Old Dec 22, 2003 | 12:51 PM
joey1320's Avatar
I'm sorry but I don't get the point of the ?'s. You want the specs to what???
Old Dec 22, 2003 | 12:53 PM
jc836's Avatar
IF you have a TD-02U distributor in an 89-91 Si you cannot replace the sensor without rebuilding the whole thing.
Old Dec 22, 2003 | 01:44 PM
415CRXSI's Avatar
Default Re: CRX Timing & dist question (joey1320)
don't I need to set it at a certain degree from TDC or BDC?
sorry, I'm a rookie, this is what my friend told me to ask
he works on domestics
Old Dec 22, 2003 | 01:59 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
look here: http://www.binghamtonlife.com/...8.jpg
Old Dec 24, 2003 | 12:16 PM
415CRXSI's Avatar
Default Re: CRX Timing & dist question (88DXCRX)
thanks thats a major help, but I can't locate the jump wire connection
I tried to time it without doing that and its SO OFF, like the red mark is about an inch forward with MAX ADVANCE
many thanks
Old Dec 24, 2003 | 12:49 PM
jc836's Avatar
2nd Gen CRX the TAN colored connector is on the drivers side apron. You will see it where the wiring harness drops down from the shock tower. Take the cover off and use a flattened paperclip (make sure it is covered with tape to insulate it). You will find several timing marks on the pulley. Turn the crank slowly and shine a light in there until you find them. Use the RED ones to set your timing.
Old Dec 24, 2003 | 04:11 PM
415CRXSI's Avatar
Default Re: CRX Timing & dist question (jc836)
Thanks JC, could this jumper be preventing the new distributor from timing correctly? Could you explain the function?
Also I have see to got an TD 020 Dist insted of a TD 018 as was on the car when I got it , they look identical except for an outside capactior on one of the cables
Could it be that my timing belt could have slipped and jumped a tooth and thats why I'm having a promlem
Many thanks for any insight
Old Dec 24, 2003 | 04:26 PM
88DXCRX's Avatar
The jumper lets the ECU know that the ignition timing is being set
so it does not alter the timing..
Here is the jumper location on '88 model:
Old Dec 24, 2003 | 04:33 PM
415CRXSI's Avatar
sweet, so when swaping a distributor, even though I lined it up pretty close to the old one (measured with a caliper) the thing ran like ****
I'll check it out tomorrow
thank you all for your help, Have a Merry Christmas
Old Dec 25, 2003 | 12:43 PM
415CRXSI's Avatar
Thanks still can't find it on my 91 SI
Also, I took off the cam gear cover, the belt has some serious play at idle, even at 2-3kRPM there is slack on the pull side !
Does anyone know if the tensioner is serviceble?
many thanks, merry christmas
Old Dec 25, 2003 | 08:24 PM
crxturboh22's Avatar
SUP MAN, i HAVE A 91 crx si with a soch Vtec.. I replaced many dist.. and now replacing the motor hehe!! its my 2nd motor.. I dind~t really get the problem with the car... I got lost half way hehe!! the car won~t start bc:::??
Old Dec 25, 2003 | 09:03 PM
415CRXSI's Avatar
Default Re: CRX Timing & dist question (crxturboh22)
ok, do you know where the jumper location is?
Old Dec 25, 2003 | 09:51 PM
Kasper.'s Avatar
Not to sound like an *******, but if your a rookie, your should have never messed with the timing, I know its your car and you gotta start somwhere, but I would have looked at another engine, or diagram or somthing before I started messing around with that.
I know from experience when I was like 15 I took the T-belt off without much consideration while changing heads on my crx. Put it back on thought I did everything right and (even I was fairly knowledgable ttthhheennn) it ran like **** for like a week, until I finally limped it to my buddys shop who fixed it in about an hour, then explained to me what I fucked up.....ive never had a prob. since
but like what happened to me happens about 9 times outta 10 to guys on this site becuase they really have no idea what theyare doing and then complain when there car runs but like **** and loses to cars they could beat before.
Old Dec 26, 2003 | 09:08 AM
415CRXSI's Avatar
Default Re: CRX Timing & dist question (Kasper 1)
Kasper, you do sound like an ***, because i ust found that I have tons of slack there, never took the belt off !
What I did need help with is locating the timing adjustment jumper as 88DX was trying to help me locate.
Modified by 415CRXSI at 9:00 PM 12/26/2003
Old Dec 27, 2003 | 11:46 AM
88DXCRX's Avatar
Ok,part of the problem is we did not know what year..
'91 manual online
On a '91 model,It is inside the car,on the passenger side kick panel
right under the glovebox..
use the top left of this picture as a reference:
ps Kasper..I have been working on Hondas longer than you have been on the planet...
Old Dec 29, 2003 | 11:38 AM
USDM91crxSi's Avatar
Thanks 88DX and all you guys! Happy Next Year!
Modified by USDM91crxSi at 10:25 PM 12/29/2003
the_dxB16
Mar 7, 2008 09:39 PM
Fresno_NSX
Nov 19, 2004 09:07 PM
mr. wu
Sep 23, 2003 07:19 PM
H23ludedude
Feb 11, 2003 11:12 AM
Pele
Nov 30, 2002 01:04 AM
