what kind of tranny u run on sohc turbo
Old Dec 20, 2003 | 11:07 PM
OoHiTzToMMy's Avatar
Default what kind of tranny u run on sohc turbo
as stated i just wanna knoe becuase i have the ex tranny and in first and second gear its all wheel spinn on the street just wanna knoe how the other trannies feel thats all
Old Dec 20, 2003 | 11:13 PM
blackeg's Avatar
Default Re: what kind of tranny u run on sohc turbo (OoHiTzToMMy)
do you have a limited slip? it should help with some traction issues.
Old Dec 20, 2003 | 11:14 PM
Default Re: what kind of tranny u run on sohc turbo (blackeg)
no i dont.......i knoe the jdm trannies have then though do u knoe how the gearin is on that trannie?
Old Dec 20, 2003 | 11:17 PM
d15nonvtec's Avatar
on the d series the jdm trans with the limited slip only came on some of the d15b's, but good luck findin one
Old Dec 21, 2003 | 12:18 AM
The Internet Tough Guy's Avatar
Default Re: what kind of tranny u run on sohc turbo (d15nonvtec)
the gearing in the rare and expensive jdm d15b tranny is exactly the same as the ex/si tranny. i'm considering one myself, but i can't find one for under $500, and even at that price it's difficult. plus you never know about the condition of it.
you don't want to run a cx / vx / dx / lx tranny; i bet you still won't have traction, you'll just be slow.
the first gears in all the trannys are the same. the second gear in the cx / vx / dx / lx trannies is slightly longer. i'm not sure if you could put that gear in there, but even if you could it would be pointless; you need traction in first gear, first.
your best bet is to get a quaife for your tranny, get a traction bar, do an equal length drive setup (i don't know much about this yet), solid motor mounts, and *learn how to modulate*.
Old Dec 21, 2003 | 12:32 AM
Daniel's Avatar
Here's Mista Bone's webpage on D-series trannies. It might help you out somewhat. http://home.cinci.rr.com/mistab0ne/tranny.html
Old Dec 21, 2003 | 12:57 AM
JDMlyfestyle's Avatar
Get a EX/SI tranny and throw in a Kaaz, Qaufie ect.
Old Dec 21, 2003 | 07:17 AM
xerox445's Avatar
Default Re: (JDMlifestyle)
B Series Swap
You could get one of those Phantom Grip mah bobers, but i think they just break your Diff after a couple of weeks.
Old Dec 21, 2003 | 07:23 AM
GTlvr82's Avatar
Default Re: (xerox445)
What about the ZC's that came in the older integ's.(like my friends '89) They are D series motors and they come with equal length driveshafts but I don't know about the gearing.
Old Dec 21, 2003 | 07:25 AM
Ricey McRicerton's Avatar
Default Re: what kind of tranny u run on sohc turbo (jwn7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwn7 &raquo;</TD></TR><TR><TD CLASS="quote">
the first gears in all the trannys are the same. the second gear in the cx / vx / dx / lx trannies is slightly longer. </TD></TR></TABLE>
I'm pretty sure that all of the first gears are NOT the same unless they have very different final drives.
EDIT: I have a dx tranny still and still have no traction in first or second gear. Either get the d15b tranny or throw a lsd in the tranny you have. y8 or d15b will always be the answer to a d series transmission question without building a hybrid.
Old Dec 21, 2003 | 07:29 AM
kKdARIAN's Avatar
Vice President/CEO
Default Re: what kind of tranny u run on sohc turbo (Daniel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daniel &raquo;</TD></TR><TR><TD CLASS="quote">Here's Mista Bone's webpage on D-series trannies. It might help you out somewhat. http://home.cinci.rr.com/mistab0ne/tranny.html</TD></TR></TABLE>
great source, good read..
Old Dec 21, 2003 | 07:44 AM
Pfieff's Avatar
I'm running a y8 tranny with a quaife and traction in first is ok. I am going to throw my polyurethane motor mounts in there and see what kind of difference that makes.
Old Dec 21, 2003 | 08:19 AM
could i use the shift forks in the new sohc trannies? i hear that they are made stonger then the 92-95 sohcs
Old Dec 21, 2003 | 10:35 AM
Simple SOHC's Avatar
Default Re: (GTlvr82)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GTlvr82 &raquo;</TD></TR><TR><TD CLASS="quote">What about the ZC's that came in the older integ's.(like my friends '89) They are D series motors and they come with equal length driveshafts but I don't know about the gearing.</TD></TR></TABLE>
I'm wondering about this too. Cause in Honda-Tuning's Budget Boost segment...they went with a ZC tranny...but never said why. Anyone know the gearing for a ZC tranny? Do all ZC trannies in the 1st gen integ have equal length driveshafts?
Old Dec 21, 2003 | 10:52 AM
94si94cx's Avatar
Default Re: (H23 EG Hybrid)
Invest in traction bars, and good sticky tires. Otherwise your problem will not be solved.
Old Dec 22, 2003 | 09:41 AM
Default Re: what kind of tranny u run on sohc turbo (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">I'm pretty sure that all of the first gears are NOT the same unless they have very different final drives.</TD></TR></TABLE>
go look at mista bones tranny page... the finals are different, but the gears are exactly the same.
also, doesn't the avc-r boost controller let you change the amount of boost for each gear? someone told me it does, but i really don't know. if that is true, get it and turn the boost down in first gear.
Old Dec 22, 2003 | 11:35 AM
Pfieff's Avatar
I used to have a y7 tranny and recently swapped it out for a y8 tranny. It made a world of difference. 3rd gear is where i noticed the most improvement.
Old Dec 22, 2003 | 12:24 PM
kommon_sense's Avatar
EDIT: I have a dx tranny still and still have no traction in first or second gear. Either get the d15b tranny or throw a lsd in the tranny you have. y8 or d15b will always be the answer to a d series transmission question without building a hybrid.</TD></TR></TABLE>
1st gear on all d-series is the exact same, but they do have different final drives. I would do the following :
1) Stop trying to drag launch on the street.
2) Replace compliance bushing on front lcas.
3) Investigate an LSD.
4) Take a look at traction bars (www.jimfab.com)
Old Dec 26, 2003 | 07:39 PM
337 GTI 1.8t's Avatar
Default Re: (94si94cx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94si94cx &raquo;</TD></TR><TR><TD CLASS="quote">Invest in traction bars, and good sticky tires. Otherwise your problem will not be solved.</TD></TR></TABLE>
Umm, i suggest an LSD, Z10 radius rods, an Ingalls engine dampener and a boost controller with scramble boost. These 4 items will solve your problems.
BTW, the 4.25/6 final drive and gearing of the y8 trans is perfect for boost, IMO
96-00 DX 2DR and 4DR had 4.06
96-00 CX/DX hatch had 3.72
Modified by 337 GTI 1.8t at 4:50 AM 12/27/2003
Old Dec 26, 2003 | 07:46 PM
Good ol' Screwtape's Avatar
Multi-paradigm
Default Re: what kind of tranny u run on sohc turbo (kommon_sense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kommon_sense &raquo;</TD></TR><TR><TD CLASS="quote">
Period.
Old Dec 26, 2003 | 09:02 PM
thrty8street's Avatar
lol
speed_demon018
Jan 7, 2009 05:18 PM
afstvx
Mar 2, 2008 12:08 PM
RFd15bhatch
Sep 15, 2005 02:29 PM
egturbo
Jan 17, 2003 01:18 PM
xXx Justin xXx
Jan 13, 2003 12:41 AM
