Honda S2000 Honda S2000
oil cooler and lines
Old Dec 20, 2003 | 12:02 PM
delux247's Avatar
Default oil cooler and lines
for those of you that are running oil coolers what size line are you running and what size cooler?
Old Dec 21, 2003 | 09:15 AM
delux247's Avatar
Default Re: oil cooler and lines (egcivicturbo)
no one uses oil coolers?
Old Jan 3, 2004 | 12:44 PM
platinum00's Avatar
6an in and 4 an out to turbo.
Old Jan 4, 2004 | 01:32 AM
evil vapor's Avatar
what kind of oil temps are you running and are you sure you need a cooler?
Old Jan 4, 2004 | 08:44 AM
DR's Avatar
DR
Default Re: oil cooler and lines (vapor)
If you are tracking your S2000 in hot climates, oil temps of over 290 Fahrenheit can be reached. A good oil cooler like a 25 row Mocal can bring down temps to the 210 range without much loss in oil pressure. 10an or 12an lines are recommended.
Old Jan 4, 2004 | 02:12 PM
evil vapor's Avatar
Default Re: oil cooler and lines (DR)
I'd say for each application, an oil guage is necessary before anything is done. You'll need one anyway, install it first, see what your temps are at, then go from there. I recommend installing the temp sensor from the pan.
Yes, a 60 degree day is cool in 50% humidity, but running the car in 30 minute sessions at these conditions fairly hard would yield an average temp of 217F, no more. I have yet to get oil temp readings in hot 100F+ weather. Some factors that may have an affect on oil temps are ride height, underbody aerodynamics/diffusers, and how hard you drive your car. I would install the oil cooler as the last thing.
Old Jan 4, 2004 | 05:25 PM
Ninja Kitty
Guest
Posts: n/a
Are even sure of the stock oil pump specs ?
it's possible that an oil cooler could cause larger problems.
Old Jan 4, 2004 | 07:01 PM
DR's Avatar
DR
Default Re: oil cooler and lines (Ninja Kitty)
If you get a good oil cooler like a Mocal and use at least -10 lines you won't have any problems since the pressure drop will only 1-3 PSI @ 3k+ RPM
Austin
Dec 31, 2017 02:56 PM
RedneckRicer
May 16, 2008 10:48 AM
realis9
May 23, 2006 08:55 PM
90crxzc
Dec 6, 2003 01:36 PM
SoulSurfer
Nov 8, 2002 06:22 AM
