idle problem
Old Dec 20, 2003 | 10:42 AM
davinci99's Avatar
Default idle problem
i have a 92 cx with a jspec SIR2 swap , its not holding a constent idle it jumps from 1500 to 3000 rpms. i checked the IAC/TPS/MAP and all the vacum lines and theres nothing wrong i even swapped all the censors with ones i have laying around . i figured id ask here and see if anybody had any insight, ive been racking my brains for a couple days trying to figre it out. the only thing that ever works is putting the car in gear and letting the clutch out and putting load on the motor for a minute with the brake up , sometimes after doing that it will idle fine for a while. thanks in advance.
Old Dec 20, 2003 | 11:27 AM
Mikey3000's Avatar
Default Re: idle problem (davinci99)
check if there's any air in your cooling system. do the "bleed air from thermostat housing" procedure.
Old Dec 20, 2003 | 12:22 PM
92civeg's Avatar
Default Re: idle problem (Mikey3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikey3000 &raquo;</TD></TR><TR><TD CLASS="quote">check if there's any air in your cooling system. do the "bleed air from thermostat housing" procedure. </TD></TR></TABLE>
what does that procedure consist of..pulling a hose off the thermo housing..and let some coolant out?
Old Dec 21, 2003 | 06:49 AM
davinci99's Avatar
any other ideas?
Old Dec 21, 2003 | 01:36 PM
Mikey3000's Avatar
Default Re: (davinci99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davinci99 &raquo;</TD></TR><TR><TD CLASS="quote">any other ideas?
what, my idea isnt good enough for you?
92civeg: you loosen the nut on top of the thermostat and let bubbles out until there's just a steady stream of coolant coming out, then tighten the nut.
Old Dec 21, 2003 | 02:59 PM
davinci99's Avatar
Default Re: (Mikey3000)
i like your idea fine just wanted to see if anybody else had any bright ones
Old Dec 22, 2003 | 04:07 AM
dustinsterk's Avatar
ttt
Old Dec 22, 2003 | 06:27 AM
davinci99's Avatar
got it thanks
Old Dec 22, 2003 | 07:08 AM
nice!
Old Dec 22, 2003 | 09:13 AM
Jimmy's Avatar
Global Moderator
Default Re: (dustinsterk)
goodjob!
Old Dec 22, 2003 | 10:23 AM
Mikey3000's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davinci99 &raquo;</TD></TR><TR><TD CLASS="quote">got it thanks</TD></TR></TABLE>
it worked?
Old Dec 22, 2003 | 12:05 PM
davinci99's Avatar
yeah it worked ,sorry if you thought i didnt believe you i just wanted some other ideas so i didnt have to post like 99 times with dumb questions. thanks again
Old Dec 22, 2003 | 05:55 PM
Mikey3000's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davinci99 &raquo;</TD></TR><TR><TD CLASS="quote">yeah it worked ,sorry if you thought i didnt believe you i just wanted some other ideas so i didnt have to post like 99 times with dumb questions. thanks again
no prob.
Da_1991
Apr 8, 2014 09:01 PM
UNKNOWN_MEMBER
Aug 11, 2005 08:56 PM
mcchau01
Aug 2, 2005 12:31 PM
E-spec Tuner
May 29, 2004 10:30 AM
94dxt
Aug 14, 2003 09:03 PM
