cold idle prob.
Old Aug 13, 2003 | 05:51 PM
94dxt's Avatar
Default cold idle prob.
When I start my car when it's cold idle goes from 1500 to 800 for about 20sec. then it's fine. Any ideas???
Thanks a ton
Old Aug 13, 2003 | 05:56 PM
mr.beeks's Avatar
Default Re: cold idle prob. (94dxt)
bleed your coolant system
Old Aug 13, 2003 | 08:04 PM
94dxt's Avatar
Default Re: cold idle prob. (francisco flores)
I've done that thrice over
Old Aug 13, 2003 | 08:46 PM
HONDADNA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94dxt &raquo;</TD></TR><TR><TD CLASS="quote">When I start my car when it's cold idle goes from 1500 to 800 for about 20sec. then it's fine. Any ideas???
Thanks a ton </TD></TR></TABLE>
Now correct if I'm wrong. When your motor is cold your idle goes from 800 RMP to 1500 RMP then back to 800 RPM correct? Then it goes back to normal when the engine is warmed up? If so, It sounds like a vaccuum leak is occurring. A quick way to verify this is but plugging the throttle body by simply covering it with hand. Of coure do this with the motor cold. If the vehicle still idle, then this verify the vaccuum leak. Next, get a can of brake clean and spray on the intake manifold gasket area and vaccuum hoses. List for an RPM change over the area that you spray brake clean on.
Old Aug 14, 2003 | 07:26 AM
94dxt's Avatar
Default Re: cold idle prob. (HONDADNA)
a vacc. leak would cause it to idle f'd up warm or cold, wouldn't it?
Old Aug 14, 2003 | 09:03 PM
HONDADNA's Avatar
Well...The reason I ask if your idle does not act up once the motor is warmed up - because it maybe a intake manifold. So, if you idle acts up only when it's cold and then goes away once it's warm - Then your problem is a vaccuum leak at your intake manifold.
The reason that it only acts it's becuase metal expand and once its was up metal contracts.
95Sedan
Oct 11, 2013 03:29 PM
DFW
Sep 29, 2007 09:07 AM
SI-vtec92
May 10, 2005 03:25 AM
jdmstreethatch
13
Apr 5, 2004 11:09 AM
