How do I check ECU code...?
search!!! there have been so many posts about this lately. You take the kick panel off on the passenger side footwell of your car and short the ecu code thing with a paperclip or something similar. Your check engine light will flash and show you what number code you have.
http://www.londonautoclub.org/...s.htm
All the info you need is here including how to and what each code means.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DiSbaDbOi »</TD></TR><TR><TD CLASS="quote">whats a test pipe? I have a straight pipe but i dunno if its called a test pipe</TD></TR></TABLE>
yes a straight pipe and a test pipe are the same thing. I have this code too because of my test pipe. I'm getting an obd1 conversion so that should take care of it.
