Check Engine
Do NOT just reset the damn ecu without pulling the code
Check the code:
http://www.hstuners.com/forums...23007
Fix whatever is wrong...THEN reset the ecu....
Check the code:
Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">Do NOT just reset the damn ecu without pulling the code
Check the code:
Fix whatever is wrong...THEN reset the ecu....</TD></TR></TABLE>i was
talking about this, try this it could be something little and you might end up paying big bucks for something small
Check the code:
well.....yeah the cel comes back on after you reset it because you didnt fix anything!
check the code, fix it, reset...it will not come back if you fix the ****.
Yes it could be from the intake if you fucked something up. It could also be ANYTHING.
<FONT SIZE="5">check the code</FONT>
